Extreme Flight 70" extra
Feral
Member
I got a bit more done today she's all hinged up Tail wheel is on, rudder servo and cables hooked up, aileron servos and linkages connected and most importantly the donk is semi bolted up. Ive used some 3" alloy standoffs I had laying around and needed another 15mm set of standoffs to get the spinner gap right the bolts I had to mount the standoffs were too short once the additional spacers were on so it's off to the bolt shop tommorow. ImageUploadedByTapatalk1370934144.945302.jpgImageUploadedByTapatalk1370934160.558411.jpgImageUploadedByTapatalk1370934175.874567.jpgImageUploadedByTapatalk1370934190.981519.jpgImageUploadedByTapatalk1370934204.034129.jpgImageUploadedByTapatalk1370934221.438008.jpgImageUploadedByTapatalk1370934235.498012.jpg. This is the gear I'm using Motrolfly DM4325 280kv and castle ice 120hv or ZTW 120hv on 8s swinging a 20x8 Xoar. Castle bec pro
Align DS615's on rudder and ailerons. Align DS515's on elevator. Precision Aerobatics 1.5" carbon servo horns on ail and elev and SWB 3" offset servo horn on the rudder.
SnowDog
The little motor that could! Looks like an awesome setup!
What are the specs on the batteries you will be using?
Feral
Member
I'll be running 2x4s 40c 4000mah HK Flightmax in series to start off with while I wait for my battery supplier to bring in some AGA Power 70c packs
Feral
Member
It does look clean joe there's plenty of room to move your gear around to balance her up. Good ol Aus post dropped the ball again so I won't have the rest of my gear till after the weekend
Feral
Member
Pat yourself on the back bud the vinyl is top quality I didn't get 1 air bubble when I layed it on.
Bigroger
That's some nice 3DRCForum vinyl there guys.
Gary, didn't know you had that gold coloured site vinyl setup like that.
I bet that would look sweet on the ailerons of the 91" extra!
Feral
Member
There pretty cool Rog. The rest of the bits should be here tommorow the maiden should be next weekend
