For Sale 82" Starduster with SE 111 RTF
Ask any Questions. This is the famous Don Bates Starduster, built to scale with his autograph. Spektrum RX. $1500. Can send more pictures and a video. Lincoln,Ne area
Explain the "SE 112" engine. Not familiar with it
SE-Engines... An Absolute Commitment to Performance!
Product Type: Gas Engine
Manufacturer: SE-Engines
Product: SE-112
Displacement: 112 cc / 6.835 cu in
Output: 11.5 hp @ 7500 rpm
Weight - Engine: 5.53 lb / 2.510 kg
Street Price: $654.99
Website: Go Now!
Phone Orders: 954.275 0498
The Engine in the 100 cc Category You Can Really Trust!
The SE-112 twin engine delivers! Just see the technical information below, and amaze yourself at the power of this beast!
Reliability, power and performance at an unbeatable price; 11.5 hp at your command. Smooth, reliable throttle response, awesome transition and mid range, extremely easy to start and no hassle operation. Need we say more?
Specifications:
Displacement: 112 cc (6.835 cu in)
Bore: 1.77 in (45 mm)
Stroke: 1.38 in (35 mm)
Weight: 6.31 lb (2.864 kg)
Engine: 5.53 lb (2510 g)
Muffler (2): 0.26 lb (117 g)
Ignition: 0.26 lb (120 g)
RPM Range: 1,300-8,500
Output: 11.5 hp @ 7,500 rpm
Pulling Force: 24.5 Kg @ 100 m altitude (54.01 lb @ 328.08’ altitude)
Pulling Force: 21.0 Kg @ 1800 m altitude (46.30 lb @ 5905.5’ altitude)
Includes: Muffler, full auto advance electronic ignition, spark plugs, gaskets, bolts, machined aluminum standoffs, operation manual and mounting template
Suggested Propellers: 26x12, 27x10 & 28x10
Suggested Break-in Prop: 26x12
Requires: unleaded gasoline, oil, ignition battery & propeller
Technical Data:
Manifold: 4-petal, V-type, reed-valve
Ignition Battery: 4.8-6.0V NiCd or NiMH, 6.6V LiFe or 7.4V LiPo pack (LiPo use requires voltage regulator.)
Compression Ratio: 7.8:1
Gas/Oil Mix: 30:1 for Break-In, 40:1 after Break-In
Muffler Volume: 56.00 cc (3.417 cu in)
Replacement Spark Plug: SE 32/56/112, CM6 or equivalent
Weight Breakdown: Engine: 5.53 lb (2510 g), Muffler (2): 0.26 lb (117 g), Ignition: 0.26 lb (120 g)
