Video...Drilling holes accurately in wood
Bartman
Defender of the Noob!
Did a quick video to demonstrate how to accurately drill holes in wood with a hand drill.
My Porter Cable cordless drill doesn't have a very high RPM range so when it really matters I use a pneumatic drill that is probably three times as fast. Using what you have isn't always bad if you know how to use what you have!
Feel free to discuss, input from the membership is always appreciated.
Bart
Ohio AV8TOR
Just Do It
Heading home for a funeral soon so no time to go into more detain but having been a wood patternmaker for 12 years drilling accurately into wood is a lot easier using Brad Point drill bits, not to mention a clean exit.
Nice demo Bart. Really glad that you showed the block on the inside of the plywood. I wanted to show a picture of what you are trying to get away from by doing that since I've seen a lot of people punch holes in places inside their airplane and not consider what could potentially happen.
Here is a pic, one with a block and one without a block in birch ply typical of what the engine box structure is made of. If you punch a hole in that without a block and it blasts out on the backside what you have done is create a focal point for vibration and stress. Sort of a "chain is only as strong as it's weakest link" kinda deal.....you just created the weak link.
Something simple can lead to problems down the line, great tip Bart!
These are good but even more important to use the block on the back and they need to be sharp. If you have those two things they work wonderfully! Same as a forstner bit but they can get a bet spendy for a good quality set.
One thing I will add when drilling in balsa wood. Mark where the hole needs to be and then use the tip of an exacto to poke very very shallow holes around in that area. Put a drop or two of CA and let it harden without kicker. Make a very small pilot hole and then drill your hole slowly with a sharp bit on high speed. Either that or use a sharpened piece of brass tubing on non-hardened balsa.
Bartman
It basically makes its own pilot hole.
We'll classify brad point drill bits in the nice-to-have category, i've got a big set of standard bits (lettered, numbered, and fractional) that I use for all kinds of materials and a Drill Doctor to keep them sharp.
With the brad point bits I'd guess you'll want to make a center mark in the wood but not drill a pilot hole.
3Dchief
Nice work ExtraJohn!!!
Agreed, get the right drill bits for the job. Compared to the money we throw away in bling for our planes, investing in the proper tools isn't much and makes building so much easier and more enjoyable.
