Build time!!!!
First things first, gotta get her onto her feet. I started by bolting the landing gear in place- the hardware for the landing gear is inside of the same bag as the axles. There should be 4 washers and 4 lock washers, lock washers go on the nut side inside of the canister tunnel.
You will want to slip your gear cuffs on and glue them in place. There are lots of different ways to fit them on, but I opted to glue them using a silicone rubber-type glue (I actually had this stuff lying around without a label so I have no idea what brand it actually it
![O O :oblong: :oblong:](/styles/default/xenforo/smilies/O_o.png)
). Seems to be sturdy..
Next up, bolting said axles in place.
This is a bit of an important step that ensures the collars will stay in place, grinding some flat spots onto the axle. Just put your wheel on and test fit the pant on to see where the wheel needs to go. Mark the positions and grind a flat spot.
Next I slipped the inside collars on and slid the wheels in place.
Outside collar on.
Lastly, bolted the pants in place using 2 bolts and 2 washers.
I went ahead and bolted the vent plates in place right now, I will start cutting the vent holes out tomorrow when there's more energy. Glue the landing gear cover plate in place using medium CA, epoxy, silicone glue, etc. I used medium CA.
That's all for tonight. She's on her mains, more work will come in the next couple of days.
You may want to opt to use blue threadlocker on all of the bolts, I did so on the main gear bolts. It'll help keep all of your nuts and bolts in place, you wouldn't want to lose your nuts would you?
Don't threadlock the vent plates in place, they will eventually need to be removed for whatever maintenance you will need to do- the forward plate serves as an access point for the bottom cowl bolts.
