talking about witch feul you use for your engine
Trump
30cc
Hello to you all; http://www.GiantScaleNews.com/forums/images/smilies/198.gif http://www.GiantScaleNews.com/forums/images/smilies/198.gif
i was wondering.
there are a lot of modelers talking about witch oil to use for there engine,
is there also interest about witch feul you use there are some different feuls to be used
for our engines
i use shell v-power at this moment and i am changing to bp ultimate with additive
here they say the octain is higher and gives better performers and the engine runs smoother with more power how much more i dont know yet
The question is
witch feul do you use at this moment
did you change feul over the years
and so on
GSNadmin
It's easy you add water to fuel and wait till the ethanol separates than drain off the water, the water will attach to the ethanol and sink to the bottom.
Xpress
I run 91 octane from either a Mobile or Chevron station, if there is a Shell nearby then I will go there. We pretty much only have ethanol fuels here, there's no way to avoid them, so instead I go to a high quality gas station and get their 91 octane.
