VTOL Aircraft World Record! DA-60 Ran Over 22 Hours Straight!
Doc
Interesting reading. Quite an accomplishment, Id like to know more about the EFI system for the powerplant. Is it true FADEC/closed loop system or what?
Doc
Doc
I have a 50 and a 100 and the manuals for both, they have Walbro carbs on them not EFI which is a quantum leap away from a carb. Wish there was more info on the unit in this story. Oh well!
Doc
Doc
True EFI or FADEC as its referred to in general aviation use (Fully Automated Digital Engine Control) requires sensors ie Exhaust (O2 Sensor) barometric, manifold, intake temp, engine temp, MAP (manifold absolute pressure) throttle position, wide open throttle and maybe others. Lastly a computer, ECU (electronic control unit) to gather all this data and send the pulses to the injector, most of these systems require about 30 psi of fuel pressure as well as controlling the ignition timing. I cant see all this in a model airplane but things keep getting smaller and lighter and I'd sure like to know more about the system in this aircraft.
Doc
Doc
I believe it, if it's really EFI and from the price if it, it seems likely. I'll have to go and read up on it, not like I could afford it but I'd just like the info.
Doc
Doc
DA site doesn't list a 12o with EFI that I can find. I was all over it last night, no joy.
Doc
