$100 OFF 70cc Sbach 342, 10% OFF Imtellimatch, Pre-Order hooded sweatshirt
TimP
Save $100 on the 70cc Sbach 342!!!
The all new 70cc Sbach!
The newly designed 92" 70cc Sbach 342 has a slightly longer tail moment and improved aerodynamics to aid in both precision and 3d type of flight. The 50cc Sbach is such a huge hit the slightly bigger 70cc Sbach is sure to please!
The cowl easily fits the PTE 72cc twin, which is an absolute perfect match.
You can also pair this 92" wingspan plane with the DA 70 twin or DLE 60cc twin.
Normal Price: $625
Sale Price: $525
SAVE $100 !!!
At checkout enter code: Sbach100
www.redwingrc.com
http://www.redwingrc.com/index.php?main_page=index&cPath=1_110
10% OFF Booma RC Intellimatch IM14 & IM22
Welcome to the world’s first Automatic Intelligent Servo Matching System (ISMS)
With Intellimatch you say goodbye to traditional methods of servo matching. The Intellimatch system automatically matches servos on 100 points through the servo sweep range.
The IM14 Intellimatch unit is designed to match 1 set of up to 4 servos. Example: 4 rudder or ailerons servos
The IM22 Intellimatch unit is designed to match 2 sets of 2 servos. Each pair of servos will run independently of each other. Example: 2 elevator or 2 ailerons servos or ailerons and flaps. IM22 is designed for each control surface using 2 servos mechanically ganged.
At checkout enter code: BOOMA10
www.redwingrc.com
http://www.redwingrc.com/index.php?..._result&search_in_description=1&keyword=booma
PRE-ORDER your RedwingRC Hooded Sweatshirt!
Limited Run!
Its getting chilly out so if you want a RedwingRC Hooded Sweatshirt then don't wait!
This will be a limited run so when they are gone, they will be gone.
Even if it's not cold where you are, you will be looking cool with this RedwingRC hooded sweatshirt!
Only $25
Small - Medium - Large - XL - 2XL - 3XL
Order Now!!!
*orders must be received by Wednesday January 20th*
www.redwingrc.com
http://www.redwingrc.com/index.php?main_page=product_info&cPath=91&products_id=661
