110" TIMBER Assembly Thread
Discussion in 'Giant / Scale ARF Build Threads' started by AKNick, Jul 16, 2019.
  1. DLE35RA
    7.7%
  2. DLE55RA
    34.6%
  3. DA35
    3.8%
  4. DA50
    34.6%
  5. OS33
    0 vote(s)
    0.0%
  6. Ummmm yeah..... I'm going electric
    11.5%
  7. EME35 But will you use the electric start version???
    0 vote(s)
    0.0%
  8. DA60
    3.8%
  9. GP61
    3.8%
  1. AKNick
    AKNick 150cc
    1,939
    3,172
    113
    Alaska
    110" TIMBER - HANGER 9 - ASSEMBLY/BUILD THREAD
    Horizon Hobby Product Link: Here
    110" Timber Manual: Here
    AKNick Completed Timber!!
    From the Website:
    Key Features
    • High quality balsa and plywood construction provides a strong and lightweight airframe
    • Vibrant and eye-catching UltraCote covering for a high-quality finish and good looks
    • Functional flaps expand the flight envelope and make for STOL take offs and landings
    • Multiple hatches allows plenty of opening space for assembly and battery change
    • Large 7" tundra-style tires included
    • Optional-use leading edge devices allows for even shorter take offs and landings (included)
    • Pre-hinged control surfaces (except rudder) help you save on build time
    • Two-piece plug-in wings with carbon fiber wing tube allows for easy transportation and storage
    • Removable horizontal stabilizer for easy field assembly
    • Accepts Hangar 9 CubCrafters XCub 60cc articulated landing gear (sold separately)
    • Tool-free field assembly
    • Painted fiberglass cowl requires no finishing by the customer
    • Painted aluminum landing gear matches the covering perfectly
    • Designed to accept gas/petrol engines and electric motors
    • Float ready, with hard points for optional float set
    • Complete hardware kit with engine and motor mounting hardware
    Enough said! Lets do a FUN, All INCLUSIVE, GSN style build thread!!!
    49dimes, HRRC Flyer, WMcNabb and 2 others like this.
  2. AKNick
    AKNick 150cc
    1,939
    3,172
    113
    Alaska
    @Snoopy1 Lets do this! As mentioned before, The "Super Timmy" barge has landed in the US, and the planes will be delivered at Horizon Hobby tomorrow morning with an estimated ship date of this Thursday or Friday.
    My LHS has one reserved for me from this first shipment!!! Wohooooooooooo EDIT: actually ended up ordering online due to shipping cost issues.
    I'm going with (Edited):
    DLE55RA w/ bowman ring, and VVRC ext throttle arm.
    3" Center Bolt Carbon Spinner (Falcon Spinner will not fit the falcon 23X8 CF Prop!!!)
    Falcon 23X8 CF Prop
    XCub Sprung gear add on
    Savox 2274 + 2270 rudder (used)
    ProModeler DS305CLHV on the throttle.
    PR 8.75" Bushwheels
    Custom 3D Printed tail-wheel bracket on the stock tail gear w/2" wheel. Ask if you need one :)
    TechAero IBEC
    Booma PinFlag Switch
    Two Pulse 2550 2S Batteries
    Fiji 17 oz fuel tank
    Futaba 18SZ w/R7014SB rx
  3. Snoopy1
    Snoopy1 640cc Uber Pimp
    5,665
    7,965
    113
    Canada
    Nick my Timber will be powered with a “X-Power 40cc Electric Motor and with a “Castle Phoenix Edge HV 120” brushless speed control”
    Will elaborate on the details later on to day going to bed.
    49dimes, pawnshopmike and AKNick like this.
  4. AKNick
    AKNick 150cc
    1,939
    3,172
    113
    Alaska
    Okay, I edited the poll.... kinda ha ha ha
    49dimes and Snoopy1 like this.
  5. Snoopy1
    5,665
    7,965
    113
    Canada
    Will be equipped with all new Deeforce JR equipment.
    Servos will be competition JR S8411. Seven
    Spinner not sure depending on the CG will be 3 inch carbon or aluminum.
    Booma pin flag switch.
    Start with the smallest propeller recommended 20-10 Falcon carbon. See how long the batteries last.
    49dimes and pawnshopmike like this.
  6. AKNick
    AKNick 150cc
    1,939
    3,172
    113
    Alaska
    Well the 110" Timber is in stock online!!!
    I called my LHS and inquired about it. He said his queue still says back ordered with an updated ETA in late August. Also the online shipping calculator quoted me $34 2nd day air... We were both shocked! He told me to pull the trigger online and see what happens since he has ten days to remove the back order. His profit margin is very small it turns out for something even this size and after local taxes, and freight charge on the barge it would hardly compete... plus it would take a couple weeks since it would be barged. A little disheartening knowing that Horizon would do this (for sale/in stock online first, push back an queue ETA that was submitted when the barge hit the water) to the brick and mortar shop. So we shall see!! It's been ordered!
  7. Snoopy1
    5,665
    7,965
    113
    Canada
    Well read through the manual looks pretty straight forward nothing out of the ordinary. Need to still order some stuff for the plane. If everything goes as planed hope to put a couple of flights on the plane before the end of the season. This will be my first electric plane of this size so there will a learning curve. Still not sure how I am going to charge the two big batteries at the field.
    Will be calling my LHS tomorrow morning to see what is happening.
  8. Yep. Happens to me every day. Not just with Horizon but with all my distributors. I can compete with the on-line price, that is, until I have to add sales tax to a high dollar item. But that’s slowly changing as more and more states start to collect sales tax on internet orders.
  9. AKNick
    AKNick 150cc
    1,939
    3,172
    113
    Alaska
    It’s too bad. Even when he gives my the buddy rate, it’s just a little more than what I can get it for. No problem, I’m supporting my friend. But when they don’t fill his back order and post them online and push his (my) order back because of it is pretty low. Which is why we decided to try the online order first and cancel it when it goes through. Anywho, enough said.
    I’ve got one coming regardless.
    49dimes, Snoopy1 and pawnshopmike like this.
  10. Snoopy1
    5,665
    7,965
    113
    Canada
    Living in Canada we do not have that option the border patrol catches us every time plus shipping cost so it is better to go through the LHS if they can get it.
    AKNick likes this.
