28x12 & 30x10
Nutball
Is this a duplicate thread of the other prop swap thread further down the list?
Used once each, balanced, 28x12 and 30x10 props with drill pattern that should fit any turnigy motor with 12mm shaft (12070 and others). You could probably redrill them for a different motor, I might be able to make a shaft hole resizer/adapter to whatever size you need to center it for drilling. Should run in the 6200-6500rpm range 70lbs or so thrust on a 120cc gas.
$50 shipped for both
Bartman
Defender of the Noob!
i did some prep work to get GSN ready for the merge and forgot I made a prop swap sub-forum already and made another tonight for the 3DRCF swap threads. thanks for the heads up, I'll merge them now.
