3DHS 126 AJ Slick
RotorJockey
Let's start with the digits off the website:
Specifications
Wingspan: 126"
Length: 119"
Wing Area: 2900 sq.in.
Weight (RTF): 42-46 lbs
Recommended Components
Engine: Desert Aircraft DA-170 or DA-200
Servos: Hitec HS-7955TG
Alternate Components
Engine: DLE-222
Servos: Hitec HS-7950TG
Required to Complete
All Electronics (See Recommended Components)
Extensions: 4x 60" Heavy Duty
2x 36" Heavy Duty
2x 24" Heavy Duty
2x 18" Heavy Duty
4x 12" Heavy Duty
Hardware: 5.5" Spinner
2" Servo Arms
Mejzlik 32x14 Propeller
Adhesives: Thin CA
5-30min Epoxy
RotorJockey
I'm putting together the components for mine and I'm kinda changing it up a bit!
I'm going to run a DLE 222 engine with a Vess 32A prop and cf spinner.
6X HS-5995TG's in the wings
4x HS-5995TG's in the elevators
2x HS-M7990TH's on the rudder, push-pull in the tail
HS-985MG for the throttle
SmartFly EQ6 Turbo Plus
52oz Fiji water bottle w/ Fox fuel cap
RotorJockey
All I have left on my shopping list is:
The prop, the 2 rudder servos, the remainder of the SWB arms, and of course, the engine.
B
Blucor Basher
Guess it's time to update the engine recommendations. The Fox200 was fun while it lasted, but they didn't sell them for very long. I'd say currently the two best choices are the DA170 and DA200, along with the DLE222.
Yeah, looked at those things real close but couldn't really figure out whether or not they were right for me based on the the pics. They should take some better pics showing them in action!
Fred
I have them in my H9 Extra. They are real nice. I did the two different lengths and used a short and long on each side opposite so I can't hook them up backwards. The two shorts won't reach each other. I'll try to snap a pict next time I have it out.
