For Sale 82" Starduster with SE 111 RTF
Discussion in 'Fueled Engines (Gas/Glow) and Parts' started by Robert lyman, Nov 27, 2017.
  1. Ask any Questions. This is the famous Don Bates Starduster, built to scale with his autograph. Spektrum RX. $1500. Can send more pictures and a video. Lincoln,Ne area
  2. pilotdb09
    pilotdb09 New to GSN!
  3. pilotdb09
    Explain the "SE 112" engine. Not familiar with it
  4. SE-Engines... An Absolute Commitment to Performance!
    Product Type: Gas Engine
    Manufacturer: SE-Engines
    Product: SE-112
    Displacement: 112 cc / 6.835 cu in
    Output: 11.5 hp @ 7500 rpm
    Weight - Engine: 5.53 lb / 2.510 kg
    Street Price: $654.99
    Website: Go Now!
    Phone Orders: 954.275 0498
    [​IMG]
    The Engine in the 100 cc Category You Can Really Trust!
    The SE-112 twin engine delivers! Just see the technical information below, and amaze yourself at the power of this beast!
    Reliability, power and performance at an unbeatable price; 11.5 hp at your command. Smooth, reliable throttle response, awesome transition and mid range, extremely easy to start and no hassle operation. Need we say more?
    [​IMG] Specifications:
    Displacement: 112 cc (6.835 cu in)
    Bore: 1.77 in (45 mm)
    Stroke: 1.38 in (35 mm)
    Weight: 6.31 lb (2.864 kg)
    Engine: 5.53 lb (2510 g)
    Muffler (2): 0.26 lb (117 g)
    Ignition: 0.26 lb (120 g)
    RPM Range: 1,300-8,500
    Output: 11.5 hp @ 7,500 rpm
    Pulling Force: 24.5 Kg @ 100 m altitude (54.01 lb @ 328.08’ altitude)
    Pulling Force: 21.0 Kg @ 1800 m altitude (46.30 lb @ 5905.5’ altitude)
    Includes: Muffler, full auto advance electronic ignition, spark plugs, gaskets, bolts, machined aluminum standoffs, operation manual and mounting template
    Suggested Propellers: 26x12, 27x10 & 28x10
    Suggested Break-in Prop: 26x12
    Requires: unleaded gasoline, oil, ignition battery & propeller
    Technical Data:
    Manifold: 4-petal, V-type, reed-valve
    Ignition Battery: 4.8-6.0V NiCd or NiMH, 6.6V LiFe or 7.4V LiPo pack (LiPo use requires voltage regulator.)
    Compression Ratio: 7.8:1
    Gas/Oil Mix: 30:1 for Break-In, 40:1 after Break-In
    Muffler Volume: 56.00 cc (3.417 cu in)
    Replacement Spark Plug: SE 32/56/112, CM6 or equivalent
    Weight Breakdown: Engine: 5.53 lb (2510 g), Muffler (2): 0.26 lb (117 g), Ignition: 0.26 lb (120 g)
Similar Threads - Starduster
  1. Robert lyman
    1
    743
