Don Hamp
These cans have 6 flights on them, no damage, like new
85/150/170cc Long Rear Dump FATS Canister Mufflers
FATS canisters have been uniquely designed with 3D flyers in mind. Their design leads to super smooth throttle response and eliminates lo-hi lag. Also, unlike competitors canisters it doesn't reduce power, in fact in many applications they increase RPM output.
FATS are designed with a standard 28MM input and have an 1 3/4" long extension at rear with a 3/4" exit hole that produces a fabulous FREE FLOW tone.
Nominal weight is 15 oz. FATS are Solely Manufactured in the USA by experienced Aero Space professionals. They use only the finest material and are fully TIG welded.
- Rear exit extends about 2.5" longer than normal
- 11" Canister Length
- 1 3/4" Exit with 28mm Inlet
- 3" Diameter
- 15 oz Weight
