A new way of using a hobby knife & other tips!
Is there a building step that always gives you trouble? Have you wondered whether there’s a better way to accomplish a particular modeling task? If so, perhaps one of these 10 helpful workshop hints will help you solve the problem or simply lead you in the right direction. You might have heard about a better way to accomplish a certain step, but it slipped your mind–until now! Cast your eyes over these 10 trusty tips to see whether one or two of them will help you cross a bothersome task off your to-do list.
1: MOTOR-BACKPLATE SLIPPAGE
Almost all motor prop adapters are smooth; they don’t have a knurled finish. This means that when you install a prop and try to tighten the nut, the adapter often slips. Small pieces of 220-grit sandpaper CA’d to the backplate surface will prevent this and secure the prop tightly. This easy fix is well worth the bit of time it takes to do.
2: REMOVING COVERING FROM BALSA SHEETING
Removing covering over balsa sheeting can be tricky. If you cut too deeply, you can compromise the wood’s integrity. By placing the blade in the knife handle as shown in the photo, you can easily adjust and control the depth of the cut. To set the blade’s depth, use it on a scrap piece of sheeting and make test cuts before you make the actual cuts on the model.
3: FAST, EFFICIENT, GLOW-PLUG IGNITER CLEANER
Oil residue can prevent glow igniters from working properly. If you carry yours in your pocket, even the lint in there can cause your igniter to malfunction. A good way to clean igniters is with alcohol and an old electric toothbrush. A clean tip on the igniter will allow more current to reach the glow-plug element for more reliable starting.
4: CONTROL-HORN MOUNT
Mounting a control horn on a tapered surface makes it difficult to align the screw holes. To keep the control-horn base square to the hinge line, install a few tapered shims. CA the control horn into place, and match-drill the holes with a drill press so that the horn aligns perfectly with the nut plate on the far side.
5: CUSTOM TRIM TAPE
When it’s time to apply trim tape to your model’s canopy (or anywhere else), and you need a special color, paint the tape with Testors Model Master water-soluble paint. It comes in a rainbow of colors, and you don’t have to buy a lot of it. It comes in 1-ounce bottles.
6: PRESSURE-GAUGE HELPER
When you encounter a leak in an air line or air cylinder in your retract system, there is a handy way to discover where the problem originates. Hook up the retract cylinders and the air-supply tank individually, and then check each component separate from the rest of the retract system; it will be much easier to find the leak.
7: SAFE COMPONENT TIE-DOWN
Mounting a plane’s electronic components takes some planning. You want them to be secure but not so tight that they absorb engine vibrations. Here, everything has been safely tied down in a neat and orderly fashion. To do this, place the component on a piece of foam, and then tie it in place with a plastic strap. Add a piece of fuel line across the top to help absorb the vibes.
8: MAGNIFICENT TRAILER
A friend of mine built this unusual trailer to haul his airplanes to the field. He found the rear end of a pickup truck at a junkyard and modified it. The great thing about this trailer is that when he pulls out the bed, all of his airplanes are within easy reach! Somehow, though, the trailer doesn’t seem to go with that expensive Hummer pulling it.
9: EXTRA WEIGHT
Often, you have to add extra weight to the nose or to the tail of an airplane to achieve the proper center of gravity (CG), and lead seems to be the material of choice for this task. Shower-base liners are made out of lead, and you can cut them into small pieces easily with scissors and then bolt them on. The lead is approximately 1/16 inch thick, and you can cut it to fit almost anywhere. Used and new shower-base liners can be purchased from plumbing-supply houses.
10: MARKING HINGE LOCATIONS
When it’s time to mark the locations of hinges, you could do it with a ruler and a pen, but there’s an easier way, and you won’t have to put a single mark on the plane! Lay a strip of masking tape on the leading edge of the control surface and on the trailing edge of the wing. Mark the hinge locations on the tape. When you’ve finished, remove the tape and apply it to the other control surface. That’s it!
BY JERRY SMITH
