Aurora 9 Throttle Curve Programming
Bemeson
Its very easy.....get the plane started and secured. Open up the throttle curve menu and advance the throttle. My guess is you have a long arm on servo and short arm on gas motor and all the throttle takes place in the first half.
The curve should be flatter in the first third and gradually get steeper as you get past half towards top end.
While the engine is running play with the curve until you get it right. The aurora 9 has one of the best throttle curve sections of any radio I have used and its been a lot.
Brian
