DA-70 and Plane Bender Smooth Pipes
Bdegan
My 35cc Plane Bender Smooth Pipe's arrived today.*
I will be getting the test stand from Tbrum this weekend and will gets things mounted up to start some testing.
Then the motor and pipe set up will be going into a build this winter. Once I decide on something LOL
Bdegan
The pipes are 22 inches long tip to tip.
20.5 inches main body, no stingers*
Diameter is 2.25 inches. Inlet is 22.5 mm
Weight is 8.6 oz each.
__________________
thurmma
I am sure I have something laying around that I could put that setup in so you don't have to agonize over it :)
Bdegan
Hmmm, interesting.
The photos upload in the reverse order they are selected. Will have to keep that in mind for future posts.
Bdegan
thurmma;5235 wrote: I am sure I have something laying around that I could put that setup in so you don't have to agonize over it :)
Send it up here. I will have a go at it :nodding-yes-by-a-ve
Bdegan
Lorne @pro-rc.ca;5275 wrote: are you going to compare to a single pipe with a y header to see the difference brad
I could if i had a 2 into 1 header. But I'm not going to be ordering one. If DA or Zimmerman wants to send me one. I will gladly test and collect data ;)
I'll be curious on this. I know after more than 50 flights on my 70 it is ripping the crap out of a 25x8W on Jtec muffs and spools up like an electric motor. This is going to be interesting!!
