Denny D
Denny drier
Hi Im new to this site. Can anyone offer suggestions on beefing up an Airbore Models ( World Models) Stearman fire wall for a 215 Moki ?
Thanks in advance
Denny
Rpw612
Hello,
If weight up front is not an issue, try adding a thicker firewall, pin it with dowels drilled from the side through the skin into the firewall.
you can Also beef it up from the inside. then epoxy coat or(?) everything inside and outside.
Denny drier
Hello,
Thanks that is a start appreciate the help
Hello,
Add to the inside suggestions, tri stock wood in the inside corners doweled as well. CF cloth on the inside epoxied also.
