Little update where this project currently stands. I had two test sessions at the air field with the engine screwed down to the fence post. Rather than display the RPM as number jumping around, the rpm was displayed in bar format in 800 rpm steps to 6000 rpm, this provided more of an analog output which is much easier to tune, after this, the fuel curve came out to just about a straight line. During the second session, the carb began to leak and I suspect the needle on the diaphragm has failed, haven't check yet.
Onto phase two of the project now. Thinking to incorporate ignition control into the controller. The tach input is already there so why not?
Here's the current plan, the system will use two Hall Sensors one set at 2-5 BTDC, this will be used for starting up to 2000 RPM., the second sensor will be mounted somewhere around 40 to 45 BTDC, this will be used for the ignition delay. This will allow variable timing with possibly more advance at low manifold pressures when the engine is at cruise and some retard from the base curve at high manifold pressures.
A Manifold Absolute Pressure sensor is added along with the current barometric sensor. The engine will start using throttle position fuel control and transition to speed density control above 2000 rpm. A RcExl ignition without advance is planned and the advance will be provided by the controller. The Seedunio XIAO controller is replaced with a ESP32 Black Pill controller that has more analog input available and more I/O in general as well. The Black Pill runs at twice the speed as well. The controller will use FrSky FBUS one wire communication that provides control and telemetry on one wire, this operates on 400000 baud rate while the previous operated at 100000 for the SBUS communication and 57000 for the telemetry communication
