Emcotec's PWC3 and PWC6 power servo harnesses
SleepyC
The Emcotec's PWC3 and PWC6 power servo harnesses have been designed using only the highest quality automotive grade, heavy duty connectors (Made In Germany) with addition of integrated housing and reverse polarity protection. No soldering necessary, simply plug your 3 or 6 wing/tail/fuselage servos to the power harness and instantly enjoy secure, multiple servo connection.
Replace your existing, or install to your brand new airplane Emcotec's revolutionary PWC Heavy Duty servo power harnesses and ensure super secure, positive snap-click, multiple servo connection.
More Information:
http://www.espritmodel.com/emcotec-pwc6-power-servo-harness-set.aspx
Xpress
Awesome. I've always liked these super neat connectors, this just looks even cleaner.
Some one just send me some!!!! I have no problem reviewing those!!! That is what I'm talking about. Those are WAY COOL!
When the Decathlon goes together I will be trying these out! NICE!
garlandk
Looks nice but don't like the side that you plug the extension or servos in. Wish it was more covered. Love the install in the wings though.
I can see making your own "custom" power expander with these and eliminate loose pig tails causing control surface "bounce".
Looks to be (guessing) 18 awg power and 22 awg signal leads.
I think I have to agree with Kevin on this one. They look nice installed, but a little "if'y" on the connections for the servo leads. Nothing to keep the servo ends locked in. Plus, even though they are rated at 11 amps continuous, our JR/Futaba style servo lead plugs are only good for 3 to 5 amps. So there really is no upside to that. Hard 3D and extreme push on our servos individually probably will never reach that 11 amp limit. Plus another thing I see is that a person would have to use extensions between the plug and the receiver or power distribution board. Thus creating another weak link for failure. Having no way to lock the servo lead in kind of scares me. The Multi-Plex offered by TDRC plugs directly into the receiver or power board. No extensions, they mount just as nicely. Servo side has regular connectors for servos which make it much easier to lock them suckers up without the fear of them coming loose. No wink links and....the best part. About 50 dead presidents cheaper.
