Engine selection for H9 Beaver 30cc
Discussion in 'Giant / Scale ARF Build Threads' started by tailskid, Apr 10, 2018.
  1. tailskid
    tailskid 70cc twin V2
    Gee this bird has a short nose! Most rear carbs engines put the carb inside the cockpit....anyone fly this bird? What engine did you use?
  2. AKNick
    AKNick 150cc
    1,222
    1,646
    113
    Alaska
    I've come across assembly threads on this bird, evolution 33 or VVRC40 with the VVRC being better on floats from FLYRC. You can find it on you tube with a 3cyl radial and an FG-40. The EME35 would be a good coice too... electric start anyone???
    stangflyer, 49dimes and pawnshopmike like this.
  3. tailskid
    EME eh? Never thought of that one.....thanks for the video.
    Jerry
    stangflyer and AKNick like this.
  4. BalsaDust
    BalsaDust Moderator
    I say 40 twin from VVRC. Love mine. It’s an awesome engine.
    stangflyer likes this.
  5. AKNick
    AKNick 150cc
    1,222
    1,646
    113
    Alaska
    I heard people have a hard time hand starting the VVRC40, is this the same with you or no?
  6. BalsaDust
    BalsaDust Moderator
    Yeah I have to put my electric starter on it the first start of the day. I have been told but haven’t tried it yet that the timing is too far advanced which gives it good power once running but hard to get to start.
  7. AKNick
    AKNick 150cc
    1,222
    1,646
    113
    Alaska
    gotcha. That was the main reason I haven't snatched one yet, I find hand starting is convenient.
  8. tailskid
    I think I will put an Evolution 26GT on the beaver.......your thoughts......
  9. AKNick
    AKNick 150cc
    1,222
    1,646
    113
    Alaska
    I would say it's too small. The beaver is actually a heavy bird with all the added scale features, a 26cc would fly it very scale in my opinion. Personally I would put a 35-40cc engine on it for a little more up and go, especially if I was on floats (will get on step faster) or with heavy bush wheels. The takeoff STOL performance would increase. I would prefer to had start as well so I would lean on the 35. Just my 2 cents.
  10. tailskid
    I guess my problem is the mounting method used by this plane. You mount the engine on the engine 'box' and then slide that into another 'box' and in so doing (due to the length of the engine -35cc- the carb is sitting way inside the fuselage. Now add a fuel tank and it ends up 1/2 way between the front and rear row of seats!
