For sale is a great flying Extreme Flight 91" Extra 300. I saw this thing fly down at the Council Bluffs Huckfest and man did it tear up the sky. I ended up buying it shortly after the event and haven't flow it much since. It needs a new home!
It is fitted with a DA 60 that has been freshly serviced and updated by Desert aircraft on June 1, 2018. I do have the invoice to back this up. The muffler is an in cowl pitts to keep the weight down.
Ignition is powered by a Tech-Aero IBEC powered by a 2S Glacier Lipo, which also powers the servos.
Rudder servo is an S9157, while the elevators and ailerons are packing the Airtronics 94780's. All are 6v servos and ran via regulators off the Glacier Lipo pack.
Specs for each are as follows:
Futaba S9157
Modulation: Digital
Torque: 6.0V: 425.00 oz-in (30.60 kg-cm)
Speed: 6.0V: 0.14 sec/60°
Weight: 2.50 oz (71.0 g)
Dimensions: Length:1.61 in (40.9 mm)
Width:0.83 in (21.1 mm)
Height:1.46 in (37.1 mm)
Motor Type: Coreless
Gear Type: Metal
Rotation/Support: Dual Bearings
Airtronics 94780
Modulation: Digital
Torque: 4.8V: 361.00 oz-in (25.99 kg-cm)
6.0V: 423.00 oz-in (30.46 kg-cm)
Speed: 4.8V: 0.19 sec/60°
6.0V: 0.15 sec/60°
Weight: 2.33 oz (66.0 g)
Dimensions: Length:1.60 in (40.6 mm)
Height:1.50 in (38.1 mm)
Gear Type: Metal
The plane is located in Grand Forks, ND and I am asking $1,200. I am willing meet withing a reasonable distance.
Take a look and enjoy.
Futaba S9157
Modulation: Digital
Gear Type: Metal
Airtronics 94780
Modulation: Digital
6.0V: 0.15 sec/60°
Gear Type: Metal
