FMS F-35 V2 PNP
From FMS:
Inspired by the superior features of the original model, version two (V2) of the FMS F-35 64mm has improved mechanical and structural features that will enhance air performance and decrease assembly time.
A fiber pipe greatly enhances the wing strength for enhanced flying maneuvers. An improved main wing set and landing gear installation optimizes strength of structure and reduces assembly time.
Plus, the latest 64mm ducted fan can achieve more than 800 grams of thrust.
The differences in speeds between the V1 and V2 will be noticeable. If you’ve got the “need for speed,” accessories such as missiles can be removed to create a faster, more streamlined model.
Features:
  • 280mm fiber pipe inserted through the fuselage and main wing
  • Use of four inner-hexagon screws instead of glue improves main wing set and landing gear installation optimizing strength of structure
  • Improved main wing set and landing gear installation. This optimizes strength of structure and reduces assembly time
  • More powerful 64mm 11-blade ducted fan with up to 800 grams of thrust
  • 2840-KV3900 motor
  • Five 9g servos
  • Predator 40A ESC
  • FMS EPO foam material creates stronger, more impact-resistant planes
  • Environmentally friendly water-based paint minimizes blistering from sun
  • Pre-installed, newly designed control horns allows more throw
Needed To Complete:
  • 4+ Channel Radio System
  • LiPo Battery and Charger
What’s in the box?
  • (1) F-35 V2 64mm PNP
  • (1) User Manual
Specs:
Aileron: Yes
Approximate Assembly Time: Less than 1 Hour
Approximate Flight Time: 5 minutes
Battery: Li-Po 11.1V 2200mAh 35C
CG (Center of Gravity): 3.6 – 3.8 in (93-98mm) From Leading Edge
Completion Level: Plug-N-Play
EDF Size: 64MM
Elevator: Yes
Flaps: No
Flying Weight: Approximately 32.5 oz (920g)
Length: 37.8 in (960mm)
Material: Durable EPO
Minimum Required Radio: 4 Channel
Motor Size: Brushless 2840-KV3900
Retracts: No
Rudder: Yes
Servos: (5) 9G Servo
Speed Control: 40A
Wingspan: 27.5 in (698mm)
#FMM091P – $149.99
Visit FMSModel.com
See more posts about FMS
