FMS Futura Jet 1060mm PNP
Discussion in 'Giant Scale News' started by GSNadmin, Jan 5, 2017.
  1. GSNadmin
    GSNadmin Staff Member
    [​IMG] [​IMG] [​IMG]
    From FMS:
    Electric Ducted Fan (EDF) jets are developing a huge following. Their speed, mobility and cost – what’s not to like? Meet the FMS Futura, which features a powerful 80mm, 12-blade EDF, a 1040mm (41.2 in) wingspan capable of producing 3400 grams of force (7.5 LBF). Plus, with a lighter EPO foam body, the Futura is as durable as it is nimble. Like speed? This is the plane for you.
    Features:
    • Powerful 3270-KV2000 motor
    • 80mm 12-blade Fan unit
    • High quality Predator 100A ESC
    • EPO40 foam material
    • Digital metal gear servos throughout for better controlling capabilities
    • New CNC-processed shock-absorbed metal landing gear set (Worm diameter, 10mm) helps to withstand those less-than-perfect landings.
    • Multi connector for one-step installation (With the latest multi-connect technology, FMS has streamlined the wiring system, eliminating wiring problems and making installation easier)
    • Oversized battery compartment
    • Button-type canopy hatch
    • No glue required, screw-together construction
    • Environmentally friendly water-based paint for better color and gloss
    Needed To Complete:
    • 6+ Channel Radio System
    • LiPo Flight Battery
    • Suitable Charger
    Specs:
    Completion Level: Plug-N-Play
    Flying Weight: Around 2500g (88.18oz)
    Length: 1170mm (46.1in)
    Motor Size: Brushless 3270-KV2000
    Recommended Motor Battery: 22.2V 4000mAh 35C (not included)
    Servos: 9g metal digital Servo x 8
    Speed Control: 100A
    Wing Area: 22 dm² (341 sq.in)
    Wing Loading: 113.6 g/dm² (0.26oz/in²)
    Wingspan: 1060mm (41.7in)
    #FMM095PPUR – Futura Jet PNP, 1060mm: Purple – $329.99
    #FMM095PRED – Futura Jet PNP, 1060mm: Red – $329.99
    Visit FMSModel.com
    See more posts about FMS
Similar Threads - Futura 1060mm
  1. dlpeirce
    6
    760
