For Sale FS: Kingtech K240 G5
Kingtech K240 G5
Selling an unused Kingtech K240 G5, as the project has been abandoned.
The turbine has merely been installed in the model.
What's new in the G5 versions:
- Very fast start-up (9–15 seconds, depending on the turbine)
- Rapid restart in the event of a flameout
- New electronics, new pump
- G5 operates on a 3S LiPo battery
K240G5
- Technical specifications:
- Diameter: 119 mm
- Length: 278 mm
- Weight: 2.0 kg
- Max. RPM: 109,000
- Thrust: 23.5 kg @ 15°C
- EGT: 750°C max.
- Digital S.Bus brushless pump (KP800DP)
- Battery: 11.1V LiPo (recommended: 2200mAh 35C)
- Start time: 10–15 seconds
- Fuel consumption: 680 g/min
- Fuel: Diesel, Jet A-1, Kerosene
- Oil mix ratio: 5%
Price: $3,000
Email: morgancharlieautoltd@gmail.com
