Kevin-Young
I have a Futaba 12zap that is my backup radio and I am no longer using. Radio has been an excellent radio with not a ton of time on it. Radio is in excellent condition with all updates and includes the following.
Includes:
-12ZAP Synthesized Transmitter
-FASST TM-14 2.4ghz Module
-Lithium Ion Transmitter Battery (2)
-LBC-1D5 Lithium Ion Transmitter Battery Charger
-Futaba 12z Single Padded Aluminum Case
-Woven Orange Neck Strap
-Instruction Manual
-Compact Flash Card
-72mhz Module
Stock Specifications:
(These are manufacturer specs and may not necessarily reflect the specs of the item for sale)
Usage: Air
Channels: 12
Modulation: PCM/PPM
Frequency: 72, 50
Computerized: Yes
General Specs:
- Trainer Mode: Both
- Mode Select: No
- 15 Models
- Model Copy
Controls and Trim:
- DigitalTrim
- Trim Reset
- Trim Memory
- Sub Trim
- Trim Step Adj.
- 12 Channel Servo Reverse
Special Functions:
- End Point Adj.
- Dual Rates
- Exponential
- ATL
- Assignable Switches
- Assignable Channels
Display Warning:
- LCD Display
- Low Battery Warning
- Timer
Applications:
- 2M Sailplanes
- 4M Sailplanes
- Competition Airplanes
- Competition Sailplane
- Electric Aircraft
- Giant
- Jets
- Large Electric Aircraft
- Pattern/Aerobatics
- Standard Sailplane
- All Purpose
- Competition
Acrobatic Functions
- Aileron Differential
- Aileron to Rudder Mixing
- Air Brake Control
- Elevator to Flap Mixing
- Elevon Function
- Flap to Aileron
- Flap to Elevator
- Flap Travel
- Flapperon Function
- Landing Mix
- RESERVED
- Snap Roll Switch
- Throttle Delay
- V-Tail Function
Sailplane Functions
- Adjustable Exponential
- Aileron to Flap Mixing
- Aileron to Rudder
- Air Brake Function
- Butterfly Mixing
- Elevator to flap
- Elevon Function
- Flap to Aileron Mixing
- Flap to Aileron Trim
- Flap to Elevator Mixing
- Flap Travel
- Speed Flap Function
- Speed Presets
- Start Presets
- V-Tail Function
- Wing Servo Function
Asking $500 + shipping
Or Best Offer
Includes:
-Instruction Manual
-Compact Flash Card
-72mhz Module
Usage: Air
Channels: 12
Modulation: PCM/PPM
Frequency: 72, 50
Computerized: Yes
General Specs:
- Mode Select: No
- 15 Models
- Model Copy
Controls and Trim:
- DigitalTrim
- Trim Reset
- Trim Memory
- Sub Trim
- Trim Step Adj.
Special Functions:
- End Point Adj.
- Dual Rates
- Exponential
- ATL
Display Warning:
- LCD Display
- Timer
Applications:
- 2M Sailplanes
- 4M Sailplanes
- Electric Aircraft
- Giant
- Jets
- All Purpose
- Competition
Acrobatic Functions
- Air Brake Control
- Elevon Function
- Flap to Aileron
- Flap to Elevator
- Flap Travel
- Landing Mix
- RESERVED
- Snap Roll Switch
- Throttle Delay
- V-Tail Function
Sailplane Functions
- Aileron to Rudder
- Butterfly Mixing
- Elevator to flap
- Elevon Function
- Flap Travel
- Speed Presets
- Start Presets
- V-Tail Function
Or Best Offer
