Giant Scale Setup — Fundamentals of Ganging Servos
On today’s giant-scale airplanes, it is a common sight to see multiple servos grouped together to command a single control surface. When you use multiple servos per surface, it is important to do it correctly.
Mechanically, control horns should be positioned close to the centerline of the servo and with the linkage’s pivot point directly over the hinge line.
Moreover, each control horn should be positioned so that the distance from the hinge line to the pivot point is the same. It’s quite easy to overlook this on an aileron where the thickness of the wing changes from the root to the tip.
Most high-quality kits and ARF models are designed to address each of these points and provide the proper starting point to assemble a capable model. Let’s focus on the programming fundamentals for such setups.
PROGRAMMING BASICS
A 120cc-size aerobatic aircraft, like the Hangar 9 Composite QQ Yak 54, has two aileron servos per aileron…
MODEL AIRPLANE NEWS PREMIUM members can access this article and many others highlighting amazing techniques, RC airplane builds and projects. When you become a member, you’ll get instant online access to our back-issue archives, the latest Model Airplane News Digital Editions, all of our newsstand-only special issues, and much more.
Membership includes exclusive access to our enormous collection of RC information.
  • 7+ years of digital editions of Model Airplane News
  • Flight Journal and Model Airplane News special issue digital editions, previously only available on newsstands
  • Free access to our magazine app through the iTunes Store – get Model Airplane News on your mobile or tablet device
  • Contests & giveaways only for members
  • 30 years of Model Airplane News archives
  • 10 years of Electric Flight archives
  • 5% off ALL Air Age Store purchases every time you shop
http://www.airagestore.com/membersh...f-exclusive-member-access-for-only-24-95.html
