SOLD! Great Planes 3D, 50cc Reactor -- $650 Lafayette, LA
les2097
This Reactor is just like NIB ... !! It has 3 flights on it... the owner, friend of mine, flew it three times and put it in his trailer and never flew it again... I bought it from him and haven't flown it... and decided to sell it...
It has a 3 run DLE 55 on the plane... with a 22x10 prop and alum. spinner...
Savox servos on everything which are new to the plane... SC-0251 and SC-0254... two on the elevators, one on rudder and four on the ailerons.
Three heavy duty charge jack switches with LEDs; NiMh batteries, two on receiver and 4.8 on the ignition; fuel filter; fuel dot.
Plane and engine are NEW... as I said 3 flights... engine needs more flights to finish breakin...
Can ship with Greyhound at buyer's expense...
SPECIFICATIONS
Wingspan: 84.5 in (2146 mm)
Wing Area: 1556 in² (100.4 dm²)
Weight RTF: 14-17 lb (6.35-7.71 kg)
Wing Loading: 21-25 oz/in² (63-77 g/dm²)
Length: 85 in (2159 mm)
Requires: 5-channel radio (6-channel recommended); 7 servos with 100 oz-in (7.2 kg-cm) torque minimum ; 2-stroke 1.6-2.2 cu in or 4-stroke 2.0-2.2 cu in glow engine; or 43-50 cc gasoline engine
