From HobbyKing:
The Hawker Hurricane is a classic fighter design from the WW2 era of aviation.
Overshadowed by the Supermarine Spitfire the Hurricane proved it’s worth during the battle of France and more notably in the Battle of Britain, shooting down more enemy aircraft than any other type. With nearly 15,000 produced and flown by many armed forces in all theaters of operation, the Hawker Hurricane is and will always be a legend in aviation.
Now you too can own your own piece of history with this version of the Sea Hurricane. Traditionally built ARF kit constructed from all balsa and lite-ply, fiberglass cowl, uniquely colored covering with weathering detail and retracts supplied all you need is your choice of engine or motor and electronics and you’re ready to fly.
The Hurricane is a joy to fly with its huge wing area making it a delight to perform all your classic fighter aerobatics maneuvers and low passes, wide track undercarriage keeps take off, landings and ground handling under control.
If you have a classic fighter size hole in your collection, then it’s time to fill it with one of the best RAF fighters ever made.
Features:
Almost ready to fly
Traditional balsa and ply construction
Classic period color scheme
Electric retracts included and preinstalled
Fibreglass cowl
Hand painted pilot figure
Designed for glow engine or electric motor
Detailed scale model
Quality hardware supplied
Specs:
Wingspan: 1486mm (58″)
Length: 1148mm (45″)
Flying weight: 2950g (dependent on equipment used)
Wing area: 35sq.dm
Wing loading: 84.3g/dm.sq (dependent on equipment used)
Included:
1 x Hawker Hurricane ARF kit
1 x Electric retracts pre-installed
1 x 80mm Spinner + related hardware
Required:
Engine or motor
Your choice of electrical equipment
Minimum five channel Transmitter and receiver
Building tools and glues
Experience with balsa and ply ARF kits
#341000073-0 – $199.04
Visit HobbyKing.com
See more posts about HobbyKing
