SOLD! Hitec Digital Mega Torque HV HS-7980TH w/Seacraft double lock 1-3/4" aluminum arms.
bobzilla
MONSTER TORQUE 611
Lightly used, excellent condition, no slop.
These sell new for $175 each.
http://www.horizonhobby.com/digital-...rsal-hrc37980s
$125 ea or $240 firm shipped CONUS for pair.
paypal ok.
Stall Torque (6.0V): 500oz/in. (36kg.cm)
Stall Torque (7.4V): 611oz/in. (44kg.cm)
The "Monster Torque" HS-7980TH is here! Designed to operate on a two cell LiPo Pack. Features our newest high resolution "G2.5" 12 bit generation programmable digital circuit and our indestructible Titanium gears. The
HS-7980TH has the performance and durability you've come to expect from a Hitec servo. The HS-7980TH has been designed for the most demanding hobby applications including the largest aircraft and monster trucks. Featuring a titanic 611oz./in. of torque at 7.4 volts, all this power is harnessed by incorporating the industries first Titanium gears for incredible wear resistance and two strong hardened steel gear pins and axial brass bushing mounted in the servo case. We offer the HS-7980TH servo in several configurations, 90° stock rotation, 180° modified rotation, continuous rotation (potentiometer is left outside the servo case) and reverse rotation. Other features in the HS-7980TH include a 7.4V optimized coreless motor, integrated heat sink case, and a top case with two hardened steel gear pins supported by axial brass bushing.
