Mini Review Hitec LiPo Checker and Balancer Review
rcdude07
Hitec LiPo Checker Battery Checker & Balancer Review
Date: March 24, 2015​
Pros
• Easy to read in daylight
• Small form factor
• Displays capacity percentage left
• Displays per cell voltage
• Balances
• Reputable company
• FlightPower/Thunder Power adapter included
• 1-6S liPo support
• No battery required, draws from the balance connector on battery
• Light weight
Cons
• No backlight
Specifications
• Applicable Battery Pack: 2-6S LiPo
• Case Size: 70 x 38 x 11mm
• Voltage Display Tolerance: +1-1.5%
• Weight: 23g
• Voltage Display Resolution: O.O1v
• Operating Temperature: 10 ~ +45'C
• Voltage Display Range: 0-5v
• Storage Temperature: -20 ~ +60'C
• Balancing Current: 50mA
I'm a long time nitro pilot but have been amassing a collection of liPos for new electric powered aircraft. With that I started looking for a good liPo checker. I borrowed one of the cheapo ones that only shows cell voltage one at a time from a buddy. I didn't like it as I wanted to know battery capacity without having to do math at the flying site. Searching through Amazon I came across this one and instantly thought that was what I'm looking for. Compared to others I found in the same price range (around $20 USD at the time of this review) the Hitec LiPo Checker was the most appealing to me, and I knew by having the Hitec name if there is to be problems I would have reliable customer support.
Unboxing
There's a piece of foam that holds the unit, in place with the rest of the box contents behind the foam. The manual is small single sheet of paper and in the language I needed (English). A wrist strap is included as well as an adapter for Thunder Power balance plugs. Everything was contained in a small box with clear plastic for the front of the liPo checker to be seen. There was also a static cling on the front display panel of the liPo checker.
Assembly
Loop the small thread of the wrist strap around the wrist strap attachment area. If needing to use the Thunder Power adapter, plug it into the liPo checker.
Using the checker
I found using the checker super easy. Just plug the balance connector (XH type supported without the Thunder Power adapter). At the time of this review only one of my liPos doesn't use the standard XH type balance connector, it's a Thunder Power battery. I found with all my 2S and 3S packs, this checker worked flawlessly. When connected correctly, the display shows the percentage of capacity left as well as each cell's voltage. After 5 seconds of being connected, it'll start to balance the cells if the difference exceeds 0.02V. When a cell is being balanced the v beside the voltage readout will blink. According the manual when the difference reaches 0.01V or less the balancing will stop and the checker will enter a sleep mode. Since I have the Hitec X1 Pro Charger, I haven't used this liPo checker to balance packs; I use my charger for that. But reading other people's thoughts/reviews on this checker indicates the balancing portion is very slow. My primary use case for this liPo checker is to check packs at the field. Even though I use three different liPo sacks (Charged, Discharged, and Storage) I want to double check and ensure I didn't misplace a pack before putting it in an aircraft, as well as to know how far away from storage charge the packs are.
Conclusion
Overall, I'm really impressed with this checker. The lack of backlight for night time/low light use doesn't bother me as I'm not into night flying. I don't regret this purchase at all and would recommend this checker to anyone.
IMG_20150210_155027.jpg IMG_20150210_155043.jpg IMG_20150210_155056.jpg IMG_20150210_155112.jpg
