HM-Modelltechnik Concorde (EDF / Turbine)
dominicm
Amazing flights by Seba Silvestri experimenting with the broad CG range of this iconic airliner. An additional kit to install the realistic nose movement is available. It can either be powered by two 90mm EDFs with 12S 8000mAh Lipos or one or two turbines.
Length: 3400mm
Wingspan: 1450mm
Engine: 2× 90mm Electric Ducted Fan or 2 x 45N turbine
Battery: 12S 8000mA/h (2x6s 8000mA/h)
Flying Time: ~ 7 Minutes
Take Off Weight: Depending on the equipment 11-12 kg
