Hobbywing Platinum Pro 100 Amp ESC
Status
Not open for further replies.
Hobbywing Platinum Pro 100 Amp ESC $40
Up for sale is my never used Hobbywing Platinum Pro 100 Amp ESC. I installed it in my newest plane and fired it up a couple of times but my motor does not like the esc. The timing will not match up so my loss will be your gain. I installed an external BEC on the power leads but removed it. Sorry I still need the BEC. I put electrical tape over the areas where I had the BEC installed in case you want to install one as well. If not just cover it up with some heat shrink and you are good to go. I would save it for another plane but I rarely build anything big enough to need a 100 amp ESC.
If you have any questions please feel free to PM me. I am asking $40.00 shipped USPS Priority Mail. Thanks for checking out my sale!
It was with the new Torque 4016/500 MKII on my 64" MXS. The timing was fine with a lipo at 3.8 volts a cell. When I put a full charge on it I set the timing on the ESC to it's highest point and it still was not syncing up. I ordered a ZTW B Series last night with a programmer. I have heard nothing but great things about the ZTW's from you and other's in the community so this gave me the opportunity to try one out. If I like them, which I am sure I will, it will be my new go to ESC manufacturer.
Thanks. Figured I should pass this guy on since I rarely ever need an ESC this big. The only other ESC I have that is over 50 amps is the one in my 71" Slick. It is a good ESC it just does not like this motor.
Status
