How to figure out what it will be
Bushwacker
3DRCF Moderator
Hey guys,
So can you guys help educate me on how to figure out what my setup will produce mathematically? Never bothered to learn how to do it and now I want to. :)
Motor: DM 4330-216Kv
ESC: Mezon 90
Battery: 2 X 3700mAh 22.2V 45C
Prop: 20x8
Example to figure out RPM, aren't you suppose to multiply volts by Kv? So in this case 44.4x216=9590.4 anyway I would like to figure out all I can mathematically.
Thanks much.
3dmike
Hey guys,
ESC: Mezon 90
Prop: 20x8
Thanks much.
This may help! Check it out and let me know if you need anything more. I believe their is another calc that has been used for quite a while as well that I can find if you need it.
http://www.ecalc.ch/motorcalc.php?ecalc&lang=en
Bbcorvette18
Volts x kv = rpm. Buy to get the good details as far amperage or watt ratings of a system I hot no idea other then the programs above lol
Bushwacker
3DRCF Moderator
[MENTION=3218]Suds[/MENTION] thanks man I like this one to. Heres what I got.
First setup is on 19x10 Prop. Second set is 20x8. Pretty sure I set all parameters right. Might be a bit light on weight though.
12S-19x10 Prop01.JPG12S-19x10 Prop02.JPG12S-20x8 Prop03.JPG12S-20x8 Prop04.JPG
