TonyHallo
As most know I picked one up at a very reasonable price, it was mounted in the plexiglass display. The box had Version I on it, I understand the made three versions while in production. When I removed the engine from the stand to check to see if the timing gear was plastic or steel I found Version II written on the Hall sensor holder. I was pleased to find steel gears in the timing case. Apparently the idler gear in the middle is the one that could be plastic and it is equipped with needle bearings.
The timing cover has two hall sensors and it looks to be adjustable. There are two plugs on the cover, three wires go to the ignition and three wires go to a micro switch mounted to the carb. The switch appears to be wired to both the NO and NC contacts. Don't know if it is a kill or a timing adjust? There are two hall sensors mounted 180 degrees arat in the timing case cover and there are two magnets on the cam gear, sound like an old dual point distributor! Need to spend some time with a multimeter to figure out the wiring
I removed the oil pan and found no oil but looks good so far. Ordered what gaskets are available from MECOA.
