Kyosho Syncro KT-431S 4 Channel Radio
Discussion in 'Giant Scale News' started by GSNadmin, Feb 23, 2017.
  1. GSNadmin
    GSNadmin Staff Member
    From Kyosho:
    This basic 4ch transmitter is inexpensive and uses a thin, lightweight casing that allows long periods of use without causing fatigue. Combined with the receiver, this set delivers secure signal transmission whether operating EP or GP models and is suitable not only with aircraft but also with yachts, cars and DRONE RACER. Includes the telemetry compatible KR-431T receiver (however, telemetry function can not be used with the KT–431S).
    Features:
    • Slip-resistant design of the sticks facilitates precision control with light touch.
    • Stick length can be adjusted within a 5mm range.
    • Reverse switch / V tail mixing switch / D/R switch (100/70)
    * All channels except the throttle change simultaneously.
    Included:
    • KT-431S transmitter
    • KR-431T receiver
    • Battery box for receiver
    • Switch for receiver
    • Binding connector
    • Instruction manual
    Required:
    • 8 X AA size batteries (4 for transmitter, 4 for receiver)
    • Servo
    Technical Data:
    Number of Channels: 4 channels
    Control Resolution: 1024
    Frequency: 2.4GHz
    Modulation System: FHSS
    Size: Transmitter : W174×L89×H190mm | Receiver : W35.4×L29.6×H13mm
    Weight: Transmitter : 334g (without batteries) |Receiver : 10g
    Power Source: Transmitter : 4 x AA alkaline batteries (6V) | Receiver : DC4-6.5V
    Antenna Output: 1.5mW/MHz
    Range: Air: 500m, Land: 300m, Water: 150m
    #82431M2B – $79.99
    Visit KyoshoAmerica.com
    See more posts about Kyosho
    [​IMG] [​IMG] [​IMG] [​IMG]
