AltitudeHobbies
GSN SPONSOR
We need them gone! Prices slashed! You won't find a better deal on a high quality performance motor.
CLICK HERE: http://www.altitudehobbies.com/brushless-motors/leopard-brushless-motors
Specs:
KV: 710
No load current (7.4v): 1.9A
Lipo cells: 3-4S
Max current: 52A
Running current: <46A
Resistance: .0278
Length of extended shaft: 20mm
Shaft diameter: 5.0mm
Dimensions: 42.5 x 47.5
Weight: 195g
Power: 700W
Pull: 3.2kg
Prop size: 12" - 13"
KV: 820
No load current (7.4v): 2.5A
Lipo cells: 3-4S
Max current: 62A
Running current: <50A
Resistance: .0209
Weight: 195g
Power: 720W
Pull: 3.3kg
Prop size: 10" - 12"
Leopard performance brushless outrunners are expertly designed and precisely constructed using the most advanced CNC components; each part adheres to the highest and strictest quality standards. Leopard Power Model Co. has over 15 years experience manufacturing high quality precision hardware, and is focused on ensuring the consistency of their products. Quality control is performed throughout the entire manufacturing process to ensure only the best materials make the cut and only the highest quality motor makes it into your RC model.
Constructed from beautifully anodized aluminum alloy and top-quality components, Leopard motors are built to last and made to endure the high-stress applications of modern 3D models. All Leopard motors deliver optimum performance, quality, and reliability at a price much less than many other premium motor brands on the market today.
Comes with pre-installed bullet connectors and includes an accessory pack with a matching set of female bullet connectors for your ESC, an X-mount plate, and prop adapter.
- Lightweight design uses reinforced materials to ensure high-speed operation under constant conditions
- High efficiency w/ low running temperatures
- Built from top-quality materials with premium imported bearings and Neodym magnets
- Dynamic balancing accuracy of at least 99%, greatly improving the efficiency of the motor
- Hand wound with precision
- High overload capacity
- Excellent heat dissipation
- Designed to endure even the most demanding applications
- Pre-installed bullet connectors
- Long service life with minimal maintenance required
- 3-bearing set
Specs:
KV: 710
Lipo cells: 3-4S
Max current: 52A
Resistance: .0278
Weight: 195g
Power: 700W
Pull: 3.2kg
KV: 820
Lipo cells: 3-4S
Max current: 62A
Resistance: .0209
Weight: 195g
Power: 720W
Pull: 3.3kg
