Help! Looking for a prop adapter
Rich B
Does anyone know if there is a 8mm (motor shaft) collet prop adapter that will accommodate wood/APC props without drilling. I would like to also run a spinner on this. I do not know what size of threaded shaft to look for. I attempted to enlarge an APC prop to the almost 1/2" diameter collet adapter I have but failed :facepalm:. Thanks in advance
Rich B
I used a prop reamer to the largest size it had. I had to finish it with a drill bit.
What size is the threaded shaft that are on the electric motors you guys are using?
