From MaxAmps.com:
MaxAmps.com brings you the latest in LiPo battery technology with our LiHV+ Plus FPV Race Edition series. These high voltage batteries will take your high-demand FPV Racer to the next level of power and performance!
The 1600HV+ 4s 15.2V battery pack has been engineered to hold a higher voltage under load during those high amp draw spikes seen in FPV racing quads. 1mm thick battery plates are installed on the top and bottom of the battery pack for added protection from crash damage. Perfect solution for bottom mounted batteries.
The consistent power and the additional milliamps will make this a must have for FPV pilots.
If you’re looking for the maximum amount of speed and the longest flight time, these are the packs for you!
You can still charge these LiHV+ batteries to only 4.2v per cell on a standard LiPo charger if preferred and they will perform like a standard LiPo battery. To unlock their full performance potential though, you will need a LiHV capable charger.
Visit MaxAmps.com
See more posts about MaxAmps.com
- 1600mah capacity
- 4S 15.2 volts
- True 150C rating
- Lifetime warranty
- 5C fast charge capable
- 100% waterproof
- Built today with factory fresh cells
- Built with genuine 12awg Deans Ultra wire
- We add the connector and JST-XH balancing tap for you
- 1mm thick battery plates installed for added durability
- 64mm x 34mm x 40mm, 175g
Visit MaxAmps.com
