New Product New From Flex MAMBA 10 PNP
Discussion in 'Giant Scale News' started by Xtreme_Power_RCS, Jan 3, 2017.
  1. Introducing the MAMBA 10 PNP
    [​IMG] [​IMG]
    Quique Somenzini
    has done it yet again!
    [​IMG][​IMG]
    Small plane with a HUGE punch of Aerobatic and 3D Capabilities
    Quique Somenzini knows how to optimize biplane aerodynamics like no other, having won F3A and 3D world championships with his biplane designs. A biplane with less coupling or better manners cannot be found.
    [​IMG]
    The Mamba 10 is a fantastic aerobatic and 3D flyer. Biplanes offer a unique challenge as every aspect of the design must be optimized, from the structure, to the aerodynamics, and control system. Only years of experience designing aircraft in this category can produce the Mamba 10's aggressive, yet forgiving characteristics. The Flex Innovations team has the ability to optimize all of these points.
    The structure is highly optimized offering an aircraft that is stiff and strong, yet light in weight. Its plywood sub-structure keeps the motor secure while offering great mounting and cooling for the battery.
    [​IMG] [​IMG]
    Not only is this a beautiful plane with the key features such as strong build, amazing looks, and able to do pretty much any aerobatic manoeuvre your willing to throw on the sticks, it also is coming with the The Aura 8 Advanced Flight Control System!
    The Aura 8 Advanced Flight Control System brings out the best of every airframe. It makes the aircraft fly as if it is
    larger and more stable and minimizes the effect of the wind. Pilots also rave about its direct and non-interfering feeling, and its ability to NOT feel 'in the way'.
    Altogether it is an unbeatable performer in a compact park-flyer package
    The Mamba is licensed by Jim Kimbal Enterprises.
    [​IMG][​IMG]
    GREAT FEATURES INCLUDED!
      • Advanced Aura 8 Control System
      • SIX Servos included! FOUR for Ailerons.
      • Innovative plywood sub-frame connects the motor securely to the fuselage while providing superior battery mounting and cooling
      • Extreme 3D Performance
      • Light wing loading for easy handling
      • Large control surfaces for excellent maneuverability
      • Shark Teeth for low speed control
      • Precise Aerobatics with nearly zero control coupling
      • Easy dissassembly for transport in small cars
      • Optimized cooling with large intakes and outlets
      • 15g metal gear Digital Servos are durable, powerful, and precise
      • Realistic biplane looks based on full scale designs
      • Powerful all metal 10 size motor with optimized Kv
      • 50A HobbyWing BL motor controller with 5V/3A SBEC
      • 11.5 x 4.5" Custom Tooled Somenzini-Ribbe (SR) Prop for awesome grip at all speeds
      • Custom control horns for optimized throw and precision
      • Large battery compartment
      • One-piece upper and lower wings
      • Factory applied trim scheme
      • CA hinges for security and free movement
    Potenza 10 1400kV Motor HobbyWing 50ESC w/SBEC
    NOT TO MENTION THE EXTREME CONTROL THROWS
    Specs
      • Length: 43.4" (1102 mm)
      • Wingspan: 40.7'' (1033 mm)
      • Weight: 54 oz. (1520 grams) with 3S 2200mAh
      • Wing Area: 691.3 sq. in (44.6 sq. dm.)
      • Channels: 6+ (recommended)
      • Battery: 2100 -to- 3300 mAh 3S 40C+ LiPo
    List Price: $359.99
    Flex Price: $309.99
    Savings: $50.00
    Save @ FlexInnovations.com
    Availability: Due Late Spring 2017!
    RECOMMENDED COMPLETION ITEMS:
      • Potenza 3S 2200 40C battery (FPZB22003S40)
      • Potenza (3) Male to Male Servo Connectors (FPZAU01)
        • Optional for '4 PWM' (servo) Rx connections
      • Potenza Battery Analyzer (FPZA1010)
      • Potenza C80 Touch Screen Charger (FPZC0080)
      • HobbyWing Programming Card (optional) (FTVHWBQ2006)
      • 6+ Channel Computer Radio recommended*
    *Works with DX4e/5e class transmitters with downloaded special configuration file.
    Go check out Flex Innovations to Preorder today!
    Brought to you by Daniel Lo'to tha'Max
    [​IMG]
  2. witchfingers
    witchfingers 70cc twin V2
    Spring!! I can't wait that long! Quique kicks butt, I need one.:adore:
    Xtreme_Power_RCS likes this.
  3. I talked to Marco @ Flex a few hours ago, he said they wont be out till March, but i havnt seen anything come from them that hasnt been top of the line, not to mention if its anything like the big brother, then this plane is going to kick :spongebob:
    And when Marco tells me something is bad Ars, then you can count on him that it is! :laughing:
