New Release: FJ-2 Fury 15 DF BNF Basic with AS3X® Technology
SleepyC
Hey guys, who doesn't love a good flying EDF jet? Especially a "pull it out of the box and go fly" BNF from Horizon?!?! I'll take two please! This week Horizon released E-flite's new FJ-2 Fury a 36" wingspan EDF jet with an awesome scale appearance and some pretty amazing flight performance.
Here's a look at this brand new plane!
EFL7250_a1.jpg EFL7250_a2.jpg EFL7250_a3.jpg EFL7250_a4.jpg EFL7250_a5.jpg EFL7250_a6.jpg EFL7250_a7.jpg EFL7250_a8.jpg EFL7250_a9.jpg EFL7250_a10.jpg EFL7250_a11.jpg
With it's bright scale markings, I'm sure even at full throttle this jet will be easy to see! Let's check out the overview and specs:
Overview
Known as one of the most famous fighters to never see combat with U.S. forces, the North American FJ-2 Fury was built for the U.S. Navy and flew with the Marines in defense against the MiG-15 threat over Korea during the 1950s. It was a jet powered dog-fighter that pilots loved and it helped to pave the way for modern super-sonic air combat. Borrowing from the success of the very similar F-86H Sabre, the Fury filled a distinctive role in a time when speed was king.
The E-flite® FJ-2 Fury airplane recreates the famous Navy jet fighter so you can enjoy thrilling jet flight at your local flying field. From the accuracy of the model outline to the efficient EDF system, this FJ-2 delivers stunning scale appearance and rock-solid performance. But the best feature of this Fury is an innovation that full-scale pilots back in the day could only dream about. Built into the included Spektrum™ AR636A receiver is an AS3X® system that’s been specially tuned for this airplane.
The advanced AS3X® (Artificial Stabilization – 3-aXis) system built into the Spektrum™ AR636A 6-channel receiver works behind the scenes to help counter the effects of wind and turbulence by combining 3-axis sensing with exclusively tuned flight control software. As a result, your workload to fly smoothly is significantly reduced so you’ll feel as if you are at the controls of an expertly tuned jet that’s much larger.
Whether you’re an intermediate pilot looking for a performance upgrade or a scale pilot looking for grab-and-go EDF convenience, the E-flite FJ-2 Fury is ideal. All you need to start flying today is the 3200mAh 4S 14.8V Li-Po flight battery a suitable charger and your favorite full-range 4+ channel aircraft transmitter with Spektrum DSM2®/DSMX® technology.
Precise Control
The Spektrum™ AR636A sport AS3X® receiver delivers rock-solid handling for a realistic jet experience.
Efficient Ducting
The internal ducting is sculpted for maximum efficiency so you get the highest level of scale accuracy and EDF performance.
Lightweight and Strong
Durable Z-Foam™ construction makes it possible to replicate complex airframe detail and keep weight low.
Scale Detail
The cockpit detail and authentic outline are true to the U.S. Navy’s first swept-wing jet.
Removable Wheels and Drop-Tanks
The fixed landing gear and drop tanks can be removed for faster flight performance.
Included:
  • Spektrum™ AR636A DSMX® 6-channel AS3X® sport receiver (installed)
  • (6) E-flite® micro servos (installed)
  • 15-size, 3700Kv brushless inrunner motor (installed)
  • 70mm fiber-filled nylon EDF unit with 5-blade rotor (installed)
  • 4S compatible, 60-Amp 14.8V brushless ESC (installed)
Key Features
  • Easy to complete final assembly
  • AS3X® technology delivers rock-solid stability and great handling
  • Durable, lightweight Z-Foam™ construction
  • Authentic outline and scale details
  • Spektrum™ AR636A DSMX® 6-Channel AS3X® sport receiver, installed
  • Powerful 70mm EDF unit features a 15-size, 3700Kv brushless motor
  • 60-amp 14.8V brushless ESC installed
  • Finely tuned ducting delivers a scale appearance
  • Six micro servos installed for aileron, elevator, rudder and nose wheel steering
  • Clear canopy, cockpit details and pilot figure
  • Removable fixed landing gear
  • Removable drop tanks
Needed To Complete
  • Full range 4+ channel DSM2®/DSMX compatible aircraft transmitter
  • High-power 3200mAh 4S 14.8V Li-Po battery
  • AC or DC 4S Li-Po battery charger
Material:Z-Foam
Wingspan:36.75 in (933mm)
Length:38.75 in (984mm)
Wing Area:304 sq in (19.6 sq dm)
Flying Weight:3.3 lbs (1.49kg)
Motor Size:BL15, 3700Kv
EDF Size:69mm
Recommended Motor Battery:14.8V 4S 3200mAh LiPo
Minimum Required Radio:5 Channel
Servos:13g
Minimum Speed Control:60A
Speed Control:60-Amp (installed)
Flaps:No
Retracts:No
Recommended Environment:Outdoor
For more information check out: Horizon Hobby
