SOLD! Robart Giant Scale P51 retracts - $200 shipped conus
bobzilla
Robart Giant Scale P51 retracts. Used but in great shape. Fully working. What you see in pic is what you get.
These are the much nicer aluminum/steel frame version, not plastic. $200 shipped conus.
Paypal OK.
Comments:
These are the scale retract units designed specifically for the Top Flite P-51DGiant Scale. This unit pivots on the outside of the unit. The hinge point is on the front of the retract unit. FEATURES: Fully functional Oleo Strut. Offset Axles to provide a scale wheel stance. Aluminum/Steel Frame with Aircraft Steel and Aluminum with Positive Up and Down Locks.SPECS: Width of retract unit: 2.5in (64mm) Length of unit: 2" (53mm) Diameter of Strut wire: 1/2" Weight Bearing Capacity: 22 to 24 pounds. Weight per pair: 23.2 oz.REQUIRES: 1-ROBQ2367 1-ROBQ2368 1 ROBQ2369 1-ROBQ2392 1 ROBQ1765 - If you want to add landing gear doors Also Requires Tee-Fittings (1/16") ROBQ0215 and Retaining Nuts Recommended that 5" Wheels are the Maximum size that can be used. COMMENTS: This unit is recommended only for the Giant P-51D Mustang from TF.RobartPart ROB6225 but may fit other applications.
[/ATTACH]
