Discussion The I’m Going/Went Flying Thread
Xpress
It would be nice if they made DA 140 from the Da35. Would be perfect for a 120 size plane and the sound and smoothness would also be great. I know some people would complain about the extra weight but I believe most of us would love to own a smaller DA140 4 cylinder.
That would be neato. They have definitely been venturing off into some new territories lately so who knows.
We can only hope, my problem would be I just love engines and would persuade my self that I need one. Then end up with an engine and then looking for something to put it in just like the Kolm engine I just could not pass up.
We just had had a perfect day for flying still cold but no wind and bright blue sky. So of to the field. 1/2 hour later just a stupid pilot error I cracked the landing gear and landing gear plate. Did not nock it off just cracked everything. So to day starts my 2026 Maintenance 6 hours later new carbon gear plate carbon gear replaced with aluminum gear. Propeller cleaned up and rebalanced. Everything reassembled and ready to just a little heavier by 1/2 oz.
Xpress
Did an electric event this last weekend in Phoenix with all the buddies, it was a much needed break from reality (which has been kicking our azz lately!). Glad we opted for a toy hauler, makes hauling a load of airplanes easier :cool:
Went flying a couple of days ago or I should say tried to go flying. Put the plane together but I just could not get it to run properly so went home. Pulled it apart completely found nothing. It was a YS120 four stroke. clean Up everything valves and piston but really did not do anything. Put it all back together put it back into the plane went to the field this morning and it flew perfectly. Happy about that but strange.
Took the latest Yak to the field for fine tuning and start up. The DLE fired up but died shortly after. Could not get it running again so hung out for a while and called it a day.
TonyHallo
From Google AI;
"The three sides of the triangle represent:
  • Fuel: Combustible material that can burn (e.g., wood, paper, gasoline, or fabric).
  • Heat: The energy or ignition source needed to raise the fuel to its ignition temperature (e.g., a match, a spark, or friction).
  • Oxygen: An oxidizing agent (typically oxygen from the surrounding air) needed to sustain the chemical combustion process.
A fire will naturally occur when all three of these elements are present in the right mixture."
What are you missing? I'm going with fuel because the engine started and died Of course once I had an engine that would not start due to lack of compression. I suspected a faulty ignition(Mag Type), a trip to the local mower repair shop came up empty however the wise repair man there suggested a few drops of oil in the cylinder, fired right up. After running a few minutes, it started normally. Why didn't it run at first? Lack of Heat from the compression process resulted in lack of vaporization of the fuel mixture which is more difficult to ignite.
Is the engine new?
The DLE came with Yak. Looks brand new inside the cowling, neat wiring, on canisters. Other than that I would have removed it and put my DA120 in.
