The Veloxity - Cody Wojcik's New Twisted Design!
Guys and gals, here is the all new foamy from Twisted Hobbys. It's big and It is epic. I wanted to share designer Cody Wojcik's words about his new design.
Greetings again Twisted brethren!
This summer, we started development of an ambitious new project. We had plenty of smaller foamies, from the awesome little pocket rockets like the mini MXS, Crack Yak, and Pitts, super light and precise indoor planes like the Edge V3 (congrats to Marek Plichta for taking 5th at the World Air Games flying this plane!) and Clik, Lite planes like the Crack Laser that are happy as both indoor monsters and go anywhere backyard flyers, tough as nails standard 32" planes like the venerable Crack Yak and MXS-C, and bigger backyard/park planes like the 39" Crack Yak and Flash. We also had the larger RCFactory 48" Sbach and Extra. But, we really had a bit of a gap in the line up, especially with the loss of some airplanes from another manufacturer.
So, we set out to develop a medium sized foamy to fill this gap. But like all projects at Twisted, we wouldn't be happy with just scaling up a smaller design and giving the same flight experience in a different size. We had to innovate! We wanted to do everything we could to take advantage of the larger size.
Enter the 43" Veloxity!
Starting with what has worked well for previous aircraft, we carefully adjusted and tweaked areas and moments, and picked a unique and specialized airfoil designed to be responsive and firm feeling without giving up stability. We also selected a thicker, denser foam construction, and RCFactory followed it all up with carbon inlays in all the right places, as well as precise ball end linkage. The resulting airframe not only is a pleasure to build, but is insanely stiff and strong with no carbon or foam external bracing!
We found that the super strong and stiff airframe was capable of supporting insane power levels, so the recommended power combo delivers just that! The Veloxity is capable of carrying 3S packs from 1500-2200 mah. A cheap 2200 mah pack will easily get you 6.5 minute flights! The new METAL GEARED and aluminum-cooled ICE servos are strong, precise, and fast.
In the air, the extra mass and stiffness delivers a flying experience never before available in a foamy. It's precise, stable, crazy when you want it to be, and can tumble and spin almost like a wood airplane. Long, high speed slow rolls right on the deck, blistering rifle rolls, super easy knife edge, and of course, all the 3D you can handle are all squarely in the Veloxity's repertoire.
If you are not yet an Xtreme Aerobatics super star, fret not. The Veloxity is extremely easy to fly with reduced control throws, and the extra mass and power will keep you in the air if there is a bit too much breeze for the 32" planes. As a stepping stone between flat foamies and a larger, more expensive balsa plane, the Veloxity is without equal. It's also durable enough to keep flying after crashes that would atomize full fuselage EPP foam planes, and simple and easy to repair after especially brutal dirt naps.
So, that was Cody's input. This is a cutting edge 3D model. The build is a lot like the MXS. There are no Rod Guides. All surfaces are connected to servos with control rods that have ball links on each end (no slop). The foam is, put simply, epic.
Check them out and get one here: http://www.twistedhobbys.com/Twisted-Hobbys-43-EPP-Veloxity-EPP-43-Velox.htm
We will have videos being released this weekend. Hope you stop in to check them out. Enjoy! - Rolling Circle
PS... Bart, you can move this if you see a better fit somewhere else... THANKS EVERYONE!!!
My TH foamie is still sitting. I need to get one of these up and running. This one looks good.
I've had a TH foamie for a couple of months mostly finished but keep loosing or breaking the little retaining clips. These appear to be great foamies though.
The clips I think you are talking about are available on Twisted's website
http://www.twistedhobbys.com/Control-Horn-Adjustable-End-Links-Control-End-Links.htm
Got flights in today and holy cow. Wait till you see this. Roll rate is a blur. Killer throws. Setup was a breeze. So much fun it's ridiculous.
Video in a little while... gotta look through some of the flights and pick out some stuff to show off...
Those are the correct ones. I ordered a 4pack and broke 3 of the retainers and lost the 4th. Tried some from Tower but they were too big so just ordered 2 more packs from Twisted.
