BalsaDust
Fired up my Cricut and made up some decals for the 104" Extra 260. Very happy with how it turned out.
The weather has changed so had some time to make a change in one of my 3D/sport planes I installed a DA50 it was just way to much for the plane. So removed the DA50 and installed a 3W-42. Hopefully a little better control. 3w-42 is just over 1lb heavier and 1hp less, time will tell If I did the right thing. Had to make transition plate to get the mounting holes to work and get the 3W-42 lined up properly.
@acerc can I ask you a question About a Valash70. Would you say that it is close to the performance of a DA50. I know it is very close to 2 lbs heavier. If my memory serves me correctly you have a couple. What would be the big difference flying a plane between the 2 engines. One question are they reliable and easy starting. Not looking for all out HP just a good quality engine and runs every time I get to the field I just hate working on my planes at the field.
acerc
The Valach's I have are excellent engines, of the highest quality, they are easy to start and starts every time. The biggest difference from a two stroke is a bigger prop, a slower throttle response, and weight. And of course, the sound, I don't even have mufflers on mine. I'll put it like this, the DA for 3D style and the Valach for scale, they have the power just a little slower throttle response. The Valach 70 will fly any airframe the DA will fly, just a little different.
