Top Flite Giant Scale P-47 Razorback 50-61cc/EP ARF
SleepyC
Built to Battle
Effective as an escort fighter, interceptor, fighter bomber, and ground attack aircraft—the P-47 was one of the most versatile aircraft of the Second World War. Although the bubble canopies of later models would become very popular with the USAAC and later airshow crowds, it was the original models with the ‘razorback’ canopies that really did the heavy lifting. Heavy armor, massive firepower, and the option to install rockets and bombs made the P-47 a lethal threat to anything moving. Get yours and make a big impression on the ground and in the air today.
Wingspan: 85 in (2,160 mm)
Wing Area: 1,329 in2 (85.7 dm2)
Weight: 19.5-21.5 lb (8.84-9.75 kg)
Wing Loading: 34-37 oz/ft2 (104-113 g/dm2)
Length: 75 in (1,905 mm)
Requires: Radio system with a minimum of 6 channels, 11-12 servos, 3200mAh minimum receiver battery, 1100mAh ignition battery (for gas engines), Robart pneumatic or electric retracts, Building and field equipment. In addition, a power system, either a 3.0-3.7 cu in (50-61 cc) gasoline engine or brushless electric 80-85 160kV motor with 160A ESC and 12S (2x6S) 5000mAh LiPo, is required.
Available: Mid August :
$729.99
