Viper #1 is ready to go.
ericb
Team WTFO
Well, as you may know I was able to purchase the original Viper 270 from [MENTION=110]Terryscustom[/MENTION] . It was designed around a DA70 with a 93" wingspan. The plan is to build new wings that will come in at about 102" I put a DLE 120 on the nose. It fit with only minor modifications to the cowl. A couple of cuts for the front of the muffle, plug cap, and a little move of the down tube holes. I put these wheels on for now in case the weather cooperates before the new ones come. I have Hitec 7950's all around.
ericb
Team WTFO
The proper size wheels are in the mail. Hopefully the new wings will be started sometime later this week. They will have split ailerons and SFG's. Anybody know the best (most affordable) place to get a tru-turn spinner? I need a 4" drilled with a DA100 bolt pattern.
ericb
Team WTFO
Here is a pic of the cowl, the internals, and while I was adjusting the aileron servos.
Daytonarc
ericb;20778 wrote: Here is a pic of the cowl, the internals, and while I was adjusting the aileron servos.
I would like buy from you. I of course need mother's approval. You need take pictures inside engine so see condition.
:devil::devil:
ericb
Team WTFO
:smile-new::smile-new:
Daytonarc;20793 wrote: I would like buy from you. I of course need mother's approval. You need take pictures inside engine so see condition.
:devil::devil:
I could open up the servos if you would like also. And then your cash can vanish.:jaded::tickled_pink:
