Dr Evil
[SIZE= 14px]This should be good :smile-new:
Ok This is my take on wing tubes and why they need to fit snug. I have seen wings 'blow apart' many times and i suspect the wing tube fit and here's why I be thinking that way. On the 55% I'm building now there is only .037 inch gap between the carbon fiber tube and wing receiver tube not much but over the large span from tip to tip it adds up a lot , and it creates a thing called (SHOCK LOAD) as well as (FLUTTER) .
Ever heard a plane flutter ? If it survives everything is checked and all the controls are tight
But you didn't think your ears were lying to you. Well it maybe time to check the tube fit
Now the SHOCK LOAD . The shock load is when the wing tube, wing and fuselage are all going different directions at the same time and one suddenly stops the other. (not the same as finding all your debit cards blocked from hobby sites but close )
Now here are some in field fixes i have seen and i don't like . one is to wrap tape around the tube in a couple of places the other is to run a strip of tape along the tube. here is why I dont like them they may help with the FLUTTER but do little to nothing for the SHOCK LOAD.
[/SIZE]
[/SIZE]
