    Dismiss Notice
Yakovlev YAK55M 1520mm Aerobatic Sports Plane (ARF)
Discussion in 'Giant Scale News' started by GSNadmin, Jan 5, 2017.
  1. GSNadmin
    GSNadmin Staff Member
    Aug 1, 2016
    547
    327
    New Jersey
    From HobbyKing:
    During the 1980’s the Soviet Union had two main manufacturers of World aerobatic championship-winning airplanes, The Sukhoi company and Yakovlev.
    In response to the Sukhoi Su-26, Yakovlev modified their Yak-55 by reducing the wingspan and introducing a more powerful 9 cylinder 360hp radial engine the Yak-55M was born, with a faster rate of climb and an improved roll rate the Yak-55 was at the tip of the spear with aerobatic sports planes.
    Our latest almost ready to fly version of the Yak-55M is built with traditional balsa and light ply construction and when combined with a powerful powertrain will give you a fantastic 3D and aerobatic machine. Professionally covered airframe and with a fiberglass color-matched cowl in a spectacular scheme will help with orientation and make you stand out from the crowd. When flying the Yak you will be able to perform all the classic aerobatic stunts from big loops to hammerhead stalls, then when you pour on the power the Yak-55M can make it look easy with all your 3D maneuvers from hovering to the more experienced rolling circles.
    Become the aerobatic champion at your club with the 20cc 60 inch Yakovlev Yak-55M.
    Features:
    • Traditionally built balsa and ply construction
    • Designed for both gas and electric power train
    • Professionally covered
    • Color matched fiberglass cowl and wheel spats
    • Lightweight aerobatic 3D sports plane
    • Great scheme for orientation
    • Almost ready to fly
    • All hardware and landing gear included
    Specs:
    Wingspan: 1520mm (60″)
    Length: 1490mm (58.5″)
    Wing area: 47.6sq.dm (738sq.in)
    Flying weight: 2300-2500g (5-5.5lbs)
    Included:
    • 1 x Yak-55M ARF
    • All required hardware
    • Comprehensive instruction manual
    Required:
    • Electric Brushless Outrunner or gas powered engine
    • Electronic speed controller
    • 5-6S LiPoly battery
    • 16×10 or 17
    • Up to 6 high voltage, digital, metal gear servos
    • Minimum 4 channel Transmitter and receiver
    • Glues and tools for an ARF RC model
    #583000003-0 – $199.31
    Visit HobbyKing.com
    See more posts about HobbyKing
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
