Your Guide to FPV Antennas
Welcome to the wonderful world of antennas, its language and culture; to the aperture family (effective and scattering), the lobe family (main, side, back, and grating); to beam widths, directivity, and gain. Antennas are three-dimensional and live in a world of beam area, steradians, square degrees, and solid angle. Antennas have impedances (self and mutual). They couple to all of space and have a temperature measured in kelvins. Antennas have polarizations: linear, elliptical, and circular. This chapter will make you fluent in the language of antennas and comfortable in its culture.
What is an Antenna
An Antenna is a transducer, which converts electrical power into electromagnetic waves and vice versa.
An Antenna can be used either as a transmitting antenna or a receiving antenna.
  • A transmitting antenna is one, which converts electrical signals into electromagnetic waves and radiates them.
  • A receiving antenna is one, which converts electromagnetic waves from the received beam into electrical signals.
  • In two-way communication, the same antenna can be used for both transmission and reception.
Antenna can also be termed as an Aerial. Plural of it is, antennae or antennas. Nowadays, antennas have undergone many changes, in accordance with their size and shape. There are many types of antennas depending upon their wide variety of applications.
Antennas have to be classified to understand their physical structure and functionality more clearly. There are many types of antennas depending upon the applications. Below are some of the types and applications.
Type of antenna Examples Applications
Wire Antennas Dipole antenna, Monopole antenna, Helix antenna, Loop antenna Personal applications, buildings, ships, automobiles, space crafts
Aperture Antennas Waveguide (opening), Horn antenna Flush-mounted applications, air-craft, space craft
Reflector Antennas Parabolic reflectors, Corner reflectors Microwave communication, satellite tracking, radio astronomy
Lens Antennas Convex-plane, Concave-plane, Convex-convex, Concave-concave lenses Used for very high frequency applications
Micro strip Antennas Circular-shaped, Rectangular shaped metallic patch above the ground plane Air-craft, space-craft, satellites, missiles, cars, mobile phones etc.
Array Antennas Yagi-Uda antenna, Micro strip patch array, Aperture array,
Slotted wave guide array
Used for very high gain applications, mostly when needs to control the radiation pattern
Need of Antenna
In the field of communication systems, whenever the need for wireless communication arises, there occurs the necessity of an antenna. Antenna has the capability of sending or receiving the electromagnetic waves for the sake of communication, where you cannot expect to lay down a wiring system. The wireless technology has made this whole process very simple. Antenna is the key element of this wireless technology.
Antenna Frequency
FPV antennas are tuned to specific frequencies so you can’t use a 2.4 GHz antenna with 5.8 GHz FPV equipment. In general the lower frequency antennas are bigger than the higher frequency ones. 95% of the time we use 5.8 GHz for FPV video so in the rest of this article we will assume all the antenna are 5.8 GHz. To learn more about frequencies have a look at our FPV transmitter guide
But before we get into the types of antennas it’s important to first understand the two types of antenna polarization.
Antenna Polarization – Linear or Circular
The first concept that you should understand is antenna polarization. There are two main categories of antennas, linear and circular polarized antennas.
Antenna-Polarization
Above: linear antenna polarization
In general linear polarization can provide extra range as all the energy is focused on a single plane rather than being dispersed into a cylindrical pattern. However in order to get good reception with linear polarized antennas you need to ensure that both antennas are aligned to ensure the radiation pattern has maximum overlap. Wireless systems such as WiFi will typically use linear antennas since the devices are stationary on the ground so it’s easy to ensure the antennas are always aligned. When using linear antennas on board your FPV drone in the sky means that when you are turning you will get less overlap, resulting in your FPV signal breaking down. The most extreme case as shown below is when the transmitter and receiver antenna are 90 degrees to one another, resulting in the least amount of signal overlap
Above: Circular antenna polarization
For this reason 99% of FPV drone pilots actually get better reception when using circular polarized (CP) FPV antennas. The fundamental advantage of circular polarized antennas is due to the corkscrew pattern you always get good overlap no matter what angle you are flying at, which is fairly important for aircraft. Another advantage of circular polarized antennas is their ability to reject multi-path signals.
LHCP and RHCP
When we talk about circular polarized antennas, we get left hand circular polarized (LHCP), and right hand circular polarized (RHCP) antennas. This simply refers to the direction of corkscrew signal that emits from the antenna. LHCP is not compatible with RHCP, so if using circular polarized antennas you need to make sure that both the transmitter and receiver both have either RHCP or LHCP antennas.
When to use Circular Polarization
  • For most drone applications its best to use circular polarized antennas
  • When you are performing acrobatic flying, or will not be staying exactly level for long duration of your flight.
When to use Linear Polarized antennas
  • Don’t have enough space to mount a circular polarized antenna
  • When your aircraft is going to be very stable (such as a slow flying photography quad copter) and you want to get more range.
Directional and Omnidirectional Antennas
Another classification of antennas is the directional polarization. Directional and Omni directional can apply to both linear and circular antennas, so you can have one directional antenna that is linearly polarized, but you can also get a circularly polarized direction antenna.
The water balloon analogy
The energy of your FPV system can be considered to behave like a water balloon. By using different antennas you essentially alter the shape of the balloon, but the total amount of water remains fixed. To get more range we can stretch the water balloon out to make it longer at the cost of reducing its width or coverage (making the balloon thinner). This is what long range antennas do by sacrificing beam width to get more range. Alternatively we can squash the waterballoon, which will make it fat, but shorter, this means we can get more coverage at the cost of reduced range with antennas which are not very long.
Types of Radiation patterns
The common types of Radiation patterns are −
  • Omni-directional pattern (also called non-directional pattern): The pattern usually has a doughnut shape in three-dimensional view. However, in two-dimensional view, it forms a figure-of-eight pattern.
  • Pencil-beam pattern – The beam has a sharp directional pencil shaped pattern.
  • Fan-beam pattern − The beam has a fan-shaped pattern.
  • Shaped beam pattern − The beam, which is non-uniform and pattern less is known as shaped beam.
A referential point for all these types of radiation is the isotropic radiation. It is important to consider the isotropic radiation even though it is impractical.
Omnidirectional antennas are great for everyday FPV flying as they provide great coverage and you don’t need to keep them pointed at your aircraft to ensure you get signal. Directional antennas (aka high gain antennas) allow you to fly further away and still receive a good FPV signal, but because the beam is narrow you always need to ensure it is pointing at your drone. You can do this by getting your friend to point at your FPV aircraft as you fly around, or invest in an antenna tracking station that will automatically pan and tilt to keep your antenna pointing at your drone/aircraft.
Using multiple antennas
In order to get the best of both worlds, some FPV systems combine two (or more) antennas on the ground receiver. This could include one omnidirectional antenna to give you good coverage. And the second antenna could be a high gain directional antenna to give you extra range in a specific direction. These systems make use of dual receiver systems (called diversity receivers) which will monitor the signal from both antennas and switch to the one that gets the best reception.
What antennas should I use for FPV?
The best antenna to start with would be a cloverleaf antenna on your receiver and a skew planar antenna on your video transmitter. Some FPV kits already include these antennas, but if not most shops sell them as a pair of FPV antennas. These are Omni directional, circular polarized antennas which work relay well for FPV.
Generally price gives a good indication on the quality and precision of the antenna. When comparing the same type of antenna from different manufactures, the more expensive one will usually have better range. This is because they are made using better materials, and with more precision. However, that is not always the case and it’s up to you if you think it is worth to pay double to get a 10% increase in range.
As you become more familiar with FPV flying and you desire more range you can upgrade to more directional systems such as a helical antenna.
Types of Antennas
Omni-directional-FPV-Antennas
Directional-FPV-Antennas
  • Helical – Circular, Directional
  • Patch – can be both Circular or Linear, Directional
  • Crosshair – Circular, Directional
  • Yagi – Linear, Directional
So that covers some of the most common antennas used for FPV flying. Hopefully this guide will help you make the best decision in what type of antenna you decide to use.
What is Gain?
The gain of an antenna is simply the measure of power of an antenna or video transmitter, measured in decibels, the formal definition is:
The decibel (dB) is a logarithmic unit of measurement that expresses the magnitude of a physical quantity (usually power or intensity) relative to a specified or implied reference level.
Antennas that you can buy will usually have a dB specification. This value gives you an idea of how the antenna will alter the radiation pattern. A perfectly isotropic antenna with 0 dB gain will have a radiation pattern that’s a perfect circle from the antenna. As you increase gain you will alter the shape of this circle pattern to squash or squeeze it to get extra range in a particular axis.
However in real life that is usually not possible so antennas such as duck antennas which have a gain of about 3dB will squad the pattern down a bit to gain extra horizontal range
As we increase gain even more with directional antennas not only is the pattern squashed more vertically, but also stretched in a particular direction horizontally to get more range in that direction.
So by increasing gain, the antenna (directional antenna) essentially stretches the radiation pattern out to form further in a specific direction to get extra range. Typically onboard your aircraft you will always use an Omni directional antenna since its always rotating but you can use a directional antenna on the ground that will need to always point at your aircraft to get extra range. Some of the larger military drones also use directional antennas onboard the aircraft mounted onto a pan-tilt module which will make them face the ground station (or satellite) to get extreme range.
Below are some of the different types of Antennas available on www.Hyperion-world.com
VENGEANCE 5.8GHZ CLOVERLEAF RHCP ANTENNA (RP-SMA)
This Antenna is a great way to improve the performance of your FPV system. This Right-Hand Circular Polarized Antenna (RHCP) helps reject “”multipath interference”, this is a problem that plagues the standard dipole stock antenna’s.
This style of Antenna has been proven to increase range and the video clarity and has become the standard aftermarket upgrade for most FPV systems. This Antenna has 3 lobes for the transmitter, which is encased in a smart 2 piece plastic molded mushroom shaped housing.
Specifications
• Frequency Range: 5725~5875GHz
• Impedance: 50 ohm
• VSWR: less than 1.5
• Gain: 7db
• Connector: RP-SMA with Flat or 90degree adapter
• Lobes: 3 Transmitter
• Polarization: Right-hand (RHCP)
click here to purchase
HYPERION 5.8GHZ 9.3DBI RHCP HELICAL ANTENNA (RP-SMA)
A new development for FPV antennas. It’s a 2.75 turn’s helix, the turns are more closely spaced than a conventional helix, and it uses a parasitic disk to achieve higher gain (9.3dBi) and better axial ratio compared to a regular helix.
The result is a very compact moderately directional antenna with very good efficiency, and same gain as a 4 turns conventional helix. The total length is less than half that of a comparable 4 turn’s helix, which slightly more than a linear patch antenna is.
Features:
• Compact directional antenna with good efficiency
• Parasitic disk design to achieve higher gain
Specifications:
• Bandwidth: 5645-5945Mhz
• Gain: 9.3dbi
• Cross polar rejection: >10dbi
• Connection: RP-SMA
• Polarity: Right Circular Polarization
• Weight: 10g
• Impedance: 50ohm
Click here to purchase
5.8GHZ DIPOLE MINI WHIP 2.8DBI ANTENNA (RP-SMA)
This 5.8Ghz Mini Whip Dipole Antenna is perfect for micro/mini quad setups.
The Hyperion Mini Whip Antenna is extremely compact and lightweight (under 4 grams). This antenna is perfect for applications where size and weight is most important.
5.8GHZ DOUBLE-RHOMBIC 9DBI PATCH ANTENNA (SMA)
The Double-Rhombic antenna design is often proclaimed to be an exceptionally good antenna with very high gain, meaning perfect for your FPV applications. This unique dual Rhombic antenna design tuned for the 5.8 GHz band gives your FPV setup unparalleled clarity and range.
Specifications:
• Frequency: 5600-5995mhz
• VSWR:
• Gain : 9.3dBi
• Impedance:50Ωohms
• Beam width: -3dB at +/- 45 degrees | Horizontal + Vertical: 80degree total)
• Connector Type: SMA
The Rhombic Antenna is an equilateral parallelogram shaped antenna. Generally, it has two opposite acute angles. The tilt angle, θ is approximately equal to 90° minus the angle of major lobe. Rhombic antenna works under the principle of travelling wave radiator. It is arranged in the form of a rhombus or diamond shape and suspended horizontally above the surface of the earth.
Frequency Range
The frequency range of operation of a rhombic antenna is around 3MHz to 300MHz. This antenna works in HF and VHF ranges.
Construction of Rhombic Antenna
Rhombic antenna can be regarded as two V-shaped antennas connected end-to-end to form obtuse angles. Due to its simplicity and ease of construction, it has many uses −
• In HF transmission and reception
• Commercial point-to-point communication
The construction of the rhombic antenna is in the form a rhombus, as shown in the figure.
The two sides of rhombus are considered as the conductors of a two-wire transmission line. When this system is properly designed, there is a concentration of radiation along the main axis of radiation. In practice, half of the power is dissipated in the terminating resistance of the antenna. The rest of the power is radiated. The wasted power contributes to the minor lobes.
Figure 1 shows the construction of rhombic antenna for point-to-point communication in olden days. Figure 2 shows the rhombic UHF antenna for TV reception, used these days.
The maximum gain from a rhombic antenna is along the direction of the main axis, which passes through the feed point to terminate in free space. The polarization obtained from a horizontal rhombic antenna is in the plane of rhombus, which is horizontal.
Radiation Pattern
The radiation pattern of the rhombic antenna is shown in the following figure. The resultant pattern is the cumulative effect of the radiation at all four legs of the antenna. This pattern is uni-directional, while it can be made bi-directional by removing the terminating resistance.
The main disadvantage of rhombic antenna is that the portions of the radiation, which do not combine with the main lobe, result in considerable side lobes having both horizontal and vertical polarization.
AdvantagesThe following are the advantages of rhombic antenna −• Input impedance and radiation pattern are relatively constant• Multiple rhombic antennas can be connected• Simple and effective transmission
DisadvantagesThe following are the disadvantages of rhombic antenna −• Wastage of power in terminating resistor• Requirement of large space• Reduced transmission efficiency
ApplicationsThe following are the applications of rhombic antenna −• Used in HF communications• Used in Long distance sky wave propagations• Used in point-to-point communications
Another method of using long wire is by bending and making the wire into a loop shaped pattern and observing its radiational parameters. This type of antennas are termed as loop antennas.
