Give-a-way contest! Win a Hanger 9 Extra 300X
Status
Not open for further replies.
Foam-Core Wings
Oversized Control Surfaces
Painted Hatch
Pre-Drilled Firewall
Genuine UltraCote® Film
Removable Wings and Tail
DuaneV
We would like to welcome everyone to the 4th annual 3D Harvest Huck. September 15-18 in Des Moines, IA.
And it would be awesome to win the Hanger9 Extra!
Status
