Nutball
Lightly used hardwood JC Super 38x12, great thrust, never flown just bench run, 12mm shaft hole, and 30mm diameter 6 bolt for M5 bolts. The tape on the prop is for balancing, it is placed on such that it shouldn't come off in flight. I don't know for sure, but this might fit a hacker A200 electric motor, or widen the bolt holes of a different engine, the bolt holes may not be precise, so center with the shaft hole before redrilling.
$120
$120
